01-14-2008, 11:04 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Sands A303i(Pinout)Tested with picture RX(RJ45-2pin) Tx(RJ45-3pin) Code: COM5 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:10F6:4697 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.05C.W06.16 Version: MALATA26_05C_HW detecting structure #2... done 60 byte(s) read imei: 35546901005889 connection Ok building list... done items to clear: 198 187 of 198 items cleared building list... done 2 items remains Finished, time used: 84 sec Remove/Install battery now ! |
The Following User Says Thank You to KK Mobile For This Useful Post: |
03-26-2008, 05:37 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Welcome Back J.A.F Age: 47
Member: 135200 Status: Offline Sonork: 100.1594691 Thanks Meter: 33 | Sands A303i Rx:8 Tx:4 Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.06 Smart-Card S/N: Smart-Card firmware version: 010E Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Initializing cable list... Initializing platforms... Initialization finished COM19 ready searching adapter at COM19... adapter found, version: 2000 Serial No: done Initializing... done Cable: 1x12 (L12C) Power On ! Power Off ! software version: 1.06 cable type: 1x12 (L12C) platform: MT6205, MT6217-MT6228 searching adapter at COM19... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 CPU: MT6205 result: Rx:8 Tx:4 time required: 36 sec |
03-26-2008, 11:34 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! thank you for sharing this pinout! will include this information in next pinout update: Sands A303i connector 1x12pin rx:8, tx:4 |
03-28-2008, 15:35 | #5 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | Quote:
03-28-2008, 20:41 | #6 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Tallinn
Member: 8496 Status: Offline Thanks Meter: 1 | hello guys! here is little trick i discovered: if pinout finder stops on second MCU pins, but you need to find first one- just repeat search procedure, but press Phone power button after CPU2 pinout. for example with sands a303i above: cpu2 pinout is 8 & 4 run pinfinder, but do not press power button until you see numbers 8 & 4. just after that press power button and wait program to detect next pair of Tx/Rx |
04-14-2008, 05:30 | #8 (permalink) | |
PB to sand logs with 2 Pisces Z310 | kifah | Universalbox | 2 | 01-04-2008 06:37 |
Service Manuals and Repairing Tips with pictures FOR New models of Sony Ericsson .etc | Sher | GSM Mobile Links | 4 | 04-21-2003 09:36 |
DCT4 Unlockers+Test Mode+Instructions with Pictures FREEEEEEEE....... | songpolk | Nokia Digital Core Technology 4 ( DCT-4 ) | 9 | 08-16-2002 20:36 |
8xxx with PICTURE EDITOR!!!!!!!! | Mehvishal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-24-2002 21:18 |
