01-27-2018, 15:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | SC/RDA Module [SCR] v1.02 USERCODE NOT DONE SPRD mode : SC6531 : REV : C000 : NOR Code: Operation : Read UserCode [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 460800 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q64 : 0x00800000 [ 8MiB ] Reading data ... Error : Memory read failed! Send log and report.log to support! Include device info also! Reconnect Power/Cable! FORMAT ALSO NOT WORK Code: SPRD mode : SC6531 : REV : C000 : NOR Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 ERROR : Baud set failed! Use default! FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q64 : 0x00800000 [ 8MiB ] Make backup of sensetive data REPAIR SECURITY NOT WORK Code: SPRD mode : SC6531 : REV : C000 : NOR Operation : Repair Security [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q64 : 0x00800000 [ 8MiB ] Code: Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q64 : 0x00800000 [ 8MiB ] Read Ok! Saved to : C:\Users\KIRUMIRA\Desktop\FLASH_DUMP kimfly t2000 fedelix.bin Done! Elapsed: 00:02:27 Reconnect Power/Cable! Code: SPRD mode : SC6531 : REV : C000 : NOR BINARY : FLASH_DUMP kimfly t2000 fedelix.bin FLSIZE : 0x00800000 Load Ok! Operation : Write Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! Done! Elapsed: 00:02:18 Reconnect Power/Cable! |
05-02-2018, 13:59 | #5 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | To avoid wasting forum space am back with another phone for password link for dump here Help me https://www.4shared.com/rar/TYh2mqzc...23_KIMFLY.html Code: Operation : Read UserCode [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q64 : 0x00800000 [ 8MiB ] Reading data ... Error : Memory read failed! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q64 : 0x00800000 [ 8MiB ] Make backup of sensetive data Last edited by Kirumira; 05-02-2018 at 14:08. |
The Following User Says Thank You to Kirumira For This Useful Post: |
05-02-2018, 14:08 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | We checked those devices and found they are little bit differs and require own FDL pair per every. Right now we finishing update with universal solution for UserCode/Format operations with them. Also will add SHIFT+Usercode - it will ask to provide link to dump and extract code from it. Will help in future, if users will not want update cards and can request help on forum from others. |
05-02-2018, 14:14 | #7 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
