09-11-2020, 16:08 | #49 (permalink) |
Junior Member Join Date: Sep 2020 Location: North Carolina, USA Age: 36
Member: 2966883 Status: Offline Thanks Meter: 0 | This is in an update file that test the modem but doesn't add the bands 12 and 13 att and t-mobile run on band 12 and verizon uses band 13 for lte # name id BlueTooth 0x191 BandSelect 0xD WIFI 0x199 MMITest 0x19A Calibration 0x2 IMEI 0x5 IMEI2 0x179 IMEI3 0x186 IMEI4 0x1E4 TD_Calibration 0x516 W_Calibration 0x12d WIFICali1 0x19F WIFICali2 0x1A0 WIFICali3 0x1A1 LTE_Calibration 0xA05 LTE_Cali_Band1 0x9C4 LTE_Cali_Band2 0xA04 LTE_Cali_Band3 0x9C8 LTE_Cali_Band4 0x9C9 LTE_Cali_Band5 0x9CA LTE_Cali_Band6 0x9CB LTE_Cali_Band7 0x9CC LTE_Cali_Band8 0x9CD LTE_Cali_Band9 0x9CE LTE_Cali_Band10 0x9CF LTE_Cali_Band11 0x9D0 LTE_Cali_Band12 0x9D1 LTE_Cali_Band13 0x9D2 LTE_Cali_Band14 0x9D3 LTE_Cali_Band15 0x9D4 LTE_Cali_Band16 0x9D5 LTE_Cali_Band17 0x9D6 LTE_Cali_Band18 0x9D7 LTE_Cali_Band19 0xA01 LTE_Cali_Band20 0xA02 LTE_Cali_Band21 0xA08 LTE_Cali_Band22 0xA09 LTE_Cali_Band23 0xA0A AFC 0x9c7 SIMLOCK_SIGN 0x1A3 SIMLOCK_PK 0x1A4 SIMLOCK_CUSTOMIZE_DATA 0x1F0 SIMLOCK_USER_DATA 0x1F1 SIMLOCK_NVCONTROL_KEY 0x1F2 SIMLOCK_KEY 0x1F4 SIMLOCK_CFG 0x7E4 |
09-11-2020, 16:19 | #50 (permalink) |
Member: 2966883 Status: Offline Thanks Meter: 0 | Plus from what I been told this cpu which has the modem in it was only used in China and they don't use the same bands for lte we do so it was never programmed to use the bands like another of phone even ones using the same ones we do in the USA they won't have the modem programmed to use bands they don't use |
02-15-2021, 11:28 | #51 (permalink) |
Freak Poster Join Date: Aug 2017 Location: IN THIS WORLD
Member: 2752048 Status: Offline Thanks Meter: 58 | spd 9850k all box dongle fail to reset ,, cm2 unisoc successfully reseted 9850 ,, useing force reset option Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe failed! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe failed! Reconnect Power/Cable! Done! Elapsed: 00:01:04 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Forced [ Format FS / Fix ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : Forced Wipe Wipe Ok : Forced Wipe Reconnect Power/Cable! Done! Elapsed: 00:03:05 |
