08-27-2009, 07:53 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Lima - Peru
Member: 272678 Status: Offline Thanks Meter: 46 | Schematic cable L5A since I bought my box and could not connect any phone with this cable. The problem is only with this cable since it works well with others I need to compare the scheme with my cable to see if it's okay help me Thanks P.D. sorry my bad english =P |
08-27-2009, 20:26 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please note that half or even more phones with L5A connector use test points on PCB for tx/rx. this might be a reason of such pinfinder behavior. DB26 cable pins 1,2,3,4,5 goes to L5A connector pins 1,2,3,4,5 |
09-10-2009, 02:20 | #3 (permalink) |
Member: 272678 Status: Offline Thanks Meter: 46 | Dont read my cable L5A. does not read any phone. What can I do? I tested the cable with multimeter it's fine. the problem is only this cable (v3 connector) |
09-11-2009, 19:57 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! for N95 8gb 90% phones keep tx/rx on PCB. check infinity pinout folder. For all others, mentioned by you- you must first make sure what type of MCU is used in them. and select it in pinfinder |
schematic cable UC-10 Universal Cable | pepenk | Cruiser Suite | 4 | 10-16-2014 20:09 |
Pinfinder cable L5A that's the only one? | nicacel | Infinity-Box | 9 | 10-10-2009 10:09 |
MY cable L5A damaged | Mang mel | SpiderMan | 0 | 08-03-2009 07:49 |
who has t191 Schematic Cable work100% | bamee | Motorola ODM | 10 | 10-01-2006 03:33 |
acer g70 schematic cable diagram needed | alitiago | Motorola ODM | 0 | 02-14-2002 07:32 |
