Old 12-18-2010, 13:49   #1 (permalink)
Member: 33166
Thanks Meter: 4
SCi iphone i9+++ which flash use to flash phone?
I have dead this phone and don't know which flash use to flash phone from support? Log:
COM5 [VCP0] selected
module v3.25
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:2C03:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 89887E00040004:89887E00000000
flash: Intel 512MBit non-mux U 64Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
total flash region size: 04000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 03C00000
checking area [00000000]: 00080000-03FFFFFF...
ffs/eeprom found near: 01D40000
Detected ffs/eeprom address is non-standard: 01D40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 01D40000
detecting ffs/eeprom size...
ffs/eeprom size: 022C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01D40000-03FFFFFF
firmware area: 00000000-01D3FFFF
detecting ffs/eeprom structure pass 1...
ffs/eeprom: can't detect record name location
error: ffs/eeprom detection failed: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
done
warning: can not detect firmware version
if software freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting firmware build...
done
detecting product-id...
done
detecting languages...
language parameters detected
warning: can not detect language names
if software freez: make "Find language names (slow process)" unchecked and repeat operation.
Finished, time used: 4 min 13 sec
Remove/Install battery now !
Thanks in advance
Old 12-18-2010, 16:16   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
can you disassemble this phone and look for printed short code version on PCB?
it is usually located near or under LCD.
telling us this short code would help us alot
Old 12-20-2010, 09:20   #3 (permalink)
Member: 33166
Thanks Meter: 4
I don't know which code, I make photo
Old 12-20-2010, 11:52   #4 (permalink)
Member: 148515
hello!
do you have anything else like on attached picture?
I mean E550_V2.1
Old 12-20-2010, 14:15   #5 (permalink)
Member: 33166
Thanks Meter: 4
I found B5_Main_V5_20091101, maybe this?
Old 12-20-2010, 20:49   #6 (permalink)
Member: 148515
hello!
unfortunately, this isnt helpful at all...
try to make search for "i9+++" on our support server and try all available different version flash files. I dont see any other way now
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.17741 seconds with 11 queries
