04-24-2012, 04:41 | #3 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 629558 Status: Offline Thanks Meter: 53 | logs......successfully format but dead. ==== [4/23/2012 9:15:56 PM] ==== COM19 [VCP0] selected module v3.51 Action: reset settings ("format ffs") Model: Asus-V66 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8A01]... CPU: MT6219 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219,E01 Date: 2004.06.18 Version: 1.2.1.4 Version: V66-ASUS-PH-R103-1-V4.5.0 Version: V61_HW 65 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 176 warning: wrong packet cs warning: wrong packet cs items cleared: 176 of 176 building list... done items remains: 0 Finished, time used: 42 sec Remove/Install battery now ! flashing successfully but still dead ==== [4/23/2012 9:26:46 PM] ==== COM19 [VCP0] selected module v3.51 Device: Asus-V66 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Asus-V66_V66-ASUS-PH-R103-1-V4.3.0_Aug-30-2005_En_Cn.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8A01]... CPU: MT6219 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:29EA0000000000 Finalization Done Finished, time used: 14 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
