GSMSERVER GSM Shop
Old 10-20-2008, 07:07   #1 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
SE T668 China Phone Repaired with PINFINITY COMBI
heres another new type of china phone which was tested with pinfinity combi.as usual problem is auto off when turned on with sim....first use pinfinder to detect the unit then use infinity to do the job.....i shared this since this is new model as shown in my logs "NEW FW DETECTED"...........
pinfinder
software version: 1.14
cable type: 1x12 SE (L12A)
platform: MT: MT62xx (autodetect)
searching adapter at COM6...
adapter found, version: 2000
pins: 12, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6226
result: Rx:6 Tx:10
time required: 32 sec
Power On !
backup
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:1541:ECC4
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
error: no any expected answer
error: no any expected answer: wrong answer after chip id request
flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
warning: wrong data size at 0x002C829C, retry...
read error recovered
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8DFA8BDA.[T6226_05C_PCB01_GPRS_MT6226_S01.A8_SE_VTRAIMF_7670 _V1016A.BIN_E55A5DD5].rpl
New firmware detected:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 8DFA8BDA
identification#1 protocol ver: 04
ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.A8_SE_VTRAIMF_7670 _V1016A.BIN
ver. sw2: A8_SE_VTRAIMF_7670_V1016A, 2AA2A51A
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[T6226_05C_PCB01_GPRS_MT6226_S01.A8_SE_VTRAIMF_7670 _V1016A.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash_SET668[T6226_05C_PCB01_GPRS_MT6226_S01.A8_SE_VTRAIMF_7670 _V1016A.BIN]_20081020-122915.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_8DFA8BDA_T6226_05C_PCB01_GPRS_MT6226_S01 .A8_SE_VTRAIMF_7670_V1016A.BIN_E55A5DD5_20081020-123743.B0X.bin
Finished, time used: 2414 sec
Remove/Install battery now !
format
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: A8_SE_VTRAIMF_7670_V1016A
Version:
detecting structure #2...
done
60 byte(s) read
imei: 35226061207033
connection Ok
building list...
done
items to clear: 172
warning: wrong packet cs
172 of 172 items cleared
0 items remains
Finished, time used: 33 sec
after format restore imei
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6226, E02
Software version: A8_SE_VTRAIMF_7670_V
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono-CPU
new imei: 352260612070338
imei verified Ok
Finished, time used: 31 sec
Power off phone now !
new firmware i share here for pinfinity team to add in database.more power
The Following 2 Users Say Thank You to alfox For This Useful Post:
Old 10-20-2008, 09:53   #2 (permalink)
Member: 148515
Thanks Meter: 16,396
hello!
thank you for sharing your experience!!
would be nice if you would send this software full backup to [email protected]
or upload to rapidshare.com
Old 10-21-2008, 12:33   #3 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
actually i uploaded it already.pls check my post #1 on the lower part.click the filename coz it contains the back up file for download....
Old 10-21-2008, 14:27   #4 (permalink)
Member: 146406
Thanks Meter: 3
thank alfox...................
Old 10-21-2008, 18:39   #5 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,569
@alfox
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Please, in future upload files to http://rapidshare.com and send files (or links) to [email protected] to avoid lost files.
Old 10-24-2008, 02:20   #6 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
ok thanks for the info and next time il do your request for uploading files....
>>> SE K610i Red Blink Repaired with TP <<< zeel_zeel SETool2 0 10-08-2008 18:11
Vote: Online pinout and China phones repair program _? osom Chinese Models & Cloned Phones 1 09-04-2008 12:00
N99 China Phone Repaired With Infinity alfox Infinity-Box 7 07-16-2008 11:48
n95 8gb china phone "HANG" repaired with PINFINITY combination alfox Infinity-Box 2 06-21-2008 07:14
China Phone Repairing Solutions cactus Hardware Repair by brands 1 10-17-2007 22:18
Page generated in 0.41250 seconds with 8 queries
