Old 07-16-2008, 13:56   #1 (permalink)
Member: 64224
Thanks Meter: 24
second imei changed but still same ?? infinity team r u there ??
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
baud set to: 57600
Phone detected, wait...
Hardware version: MT6205B, E0
Hardware version: AHONG_NEPC06B_HW
Software version: MAUI.06B.W07.04.MP.V
Software date: 2003.07.29
Barcode: MT012345678901234567
imei: 3537980***xx235
imei write method: mode-1
new imei: 3537980***xx235
imei verified Ok
Finished, time used: 12 sec
Power off phone now !
i changed 1st cpu perfectly... but second cpu cannot change .. looking changed..but still phone have same 2nd imei...
what is the problem ?? how can i solve this problme???
Old 07-16-2008, 18:07   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
use IMEI changing method 3
Old 07-17-2008, 10:33   #3 (permalink)
Member: 64224
Thanks Meter: 24
COM5 [VCP0] selected
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: imei
imei write method: mode-3
new imei: 350736815764803
Boot...
19200 fixed
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01224900000000:18E59F00000000
flash: Amd AMD/Fujitsu std [B 0008x002000 001Fx010000] 2Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00200000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: STD_NEP05C_PCB01_GSM_MT6205B_DN.TL_MODULE_00_17.BI N
ver. sw2: TL_MODULE_00.17, 00000000
ffs offset/size: 001C0000/00040000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 001C0000
checking area[00000000]: 00000000-001FFFFF...
eeprom/ffs found near: 001C0000
detecting eeprom/ffs size...
eeprom/ffs size: 00040000
ffs chip: 00
eeprom/ffs area: 00000000:001C0000-001FFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[STD_NEP05C_PCB01_GSM_MT6205B_DN.TL_MODULE_00_17.BI N]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[STD_NEP05C_PCB01_GSM_MT6205B_DN.TL_MODULE_00_17.BI N]_20080717-123055.B0E.bin
Backup required data Done
Patch required data...
3 step(s) required to finalize
Patch required data Done
Special operation...
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Finished, time used: 56 sec
Remove/Install battery now !
still same this is different phone... i tried with mode 1 and mode3.... in mode2 not done
what can i do ??
E1107 success IMEI Rebuild but still the same dmaetrey Z3X-Team Products 7 12-11-2009 09:25
5200 keypaid ic change but still same zargar322 Nokia Hardware & Hardware Repair 33 02-24-2009 09:51
L6 cemera hang then i flash but still same aukonline Smart-Clip 3 07-11-2007 21:18
V525 blue screen and turns off. flashed but still same crossings Motorola P2k 4 09-02-2004 09:36
t500 imei changed but still locked mp3hot UST Pro II 0 03-08-2004 01:14
Page generated in 0.17398 seconds with 9 queries
