Old 05-14-2018, 07:57   #1 (permalink)
Member: 742407
Thanks Meter: 12
cm2mt2 not Identify/Connect
when click identify/Connect show..
Operation : Read Firmware [ v2.00 r2 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek DA USB VCOM Port (COM569)
MODE : PRELOADER PORT
PORT : 569
Error : Failed to open port!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Reconnect Power/Cable!
how to fix it?
Old 05-14-2018, 08:07   #2 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
PORT : 569
how to fix it?
Bro this is problem. Try to Bring your com port to down then try again.
Old 05-14-2018, 08:30   #3 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
PORT : 569
how to fix it?
Yes not work. infinity CM2 MT2 . it is bug problem. infinity team please solve the problem
Old 02-07-2019, 08:22   #4 (permalink)
Member: 2876424
Did you solve the problem? Cause 'm facing same problem.
Old 02-07-2019, 10:25   #5 (permalink)
Member: 1677653
Thanks Meter: 2,769
Reboot your PC and press F8 then select DISABLE DRIVER SIGNATURE
that's all.
Old 02-07-2019, 10:32   #6 (permalink)
Member: 2876424
I'm running with windows 7. Why would i need to do this?
Old 02-07-2019, 10:36   #7 (permalink)
Member: 1677653
Thanks Meter: 2,769
Try it and see.....
It worked for me
Old 02-10-2019, 11:09   #8 (permalink)
Member: 2876424
Didn't work for me...
Old 02-10-2019, 11:59   #9 (permalink)
Member: 1884292
Thanks Meter: 33
just uninstall driver & install manually
Old 02-20-2019, 14:21   #10 (permalink)
Member: 2896166
how to fix this ? same problem
Old 02-20-2019, 14:23   #11 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
try another pc or setup your pc.i have done it.
The Following User Says Thank You to kothamamun For This Useful Post:
Old 07-10-2021, 06:53   #12 (permalink)
Member: 2162447
windows 10 just unstall mtk vcom driver it will work that is what i did.
The Following User Says Thank You to kamsaunyirenda For This Useful Post:
Page generated in 0.22258 seconds with 8 queries
