07-04-2021, 14:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Peace Age: 27
Member: 2441366 Status: Offline Sonork: Telegram: @FahadBoss10 Thanks Meter: 245 | Redmi 9C fully dead flashing failed! Code: Operation : Identify [ v2.25 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 1723126C09A0515A6D7BBA6432507CE9 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 99595DE9FBC9A23C52E192196F1666FD93956B4DD68859369B94F540265B1B02 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_2 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100434A54443452049CF0BCBB972B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 434A54443452 EMMC: VEN : SAMSUNG : CJTD4R EMMC: SNN : 2633022651 ( 0x9CF0BCBB) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3247C7C2F4BFF75234045A0BB5FA192B DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! HW Report: Code: Operation : HW Report [ v2.25 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 1723126C09A0515A6D7BBA6432507CE9 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 99595DE9FBC9A23C52E192196F1666FD93956B4DD68859369B94F540265B1B02 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_2 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100434A54443452049CF0BCBB972B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 434A54443452 EMMC: VEN : SAMSUNG : CJTD4R EMMC: SNN : 2633022651 ( 0x9CF0BCBB) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3247C7C2F4BFF75234045A0BB5FA192B DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 150100434A54443452049CF0BCBB972B MEM : VEN : SAMSUNG | OEM : 01 | DEV : CJTD4R DAT : Size: 59640 MB, Max.Speed: 52000 kHz, blklen(512), nblks(122142720), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 8100 ms Secure trim timeout : 5100 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 300 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 747c000h Min. WR Perf. (52MH,8b): 0h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 0h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 0h Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 2h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 4096 kbytes Write rel. setting : 1fh Write rel. parameter: 14h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : e8fh (30531584 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:00:28 Write flash: Code: Operation : Write Flash [ v2.25 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :23 [FL] : Set : preloader_k65v1_64_bsp.bin [FL] : Set : recovery.img [FL] : Set : cust.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : efuse.img [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : super.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x17E4A7710 [ 5.97 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 1723126C09A0515A6D7BBA6432507CE9 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 99595DE9FBC9A23C52E192196F1666FD93956B4DD68859369B94F540265B1B02 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 000B EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [02] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [03] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [04] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [05] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [06] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [07] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [08] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : [09] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [0A] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100434A54443452049CF0BCBB972B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 434A54443452 EMMC: VEN : SAMSUNG : CJTD4R EMMC: SNN : 2633022651 ( 0x9CF0BCBB) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3247C7C2F4BFF75234045A0BB5FA192B DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x000000003BE88000 ERR : 0xC0040001 ERR : UNSUPPORT OPERATION ERR : 0x00000000|0x00000000 [DEBUG] : ERASE_BREAK , Skip erase [FL] : RePartition ERR : 0xC0040030 ERR : MMC ERROR ERR : 0x00004400|0x00004400 [DEBUG] : REPARTITION_BREAK , Skip repartition [FL] : Flashing now ... Write : PRELOADER FAIL : MMC ERROR ERR : 0xC0040030 ERR : MMC ERROR ERR : 0x00000000|0x0003B6EC Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Init GPT: Code: Operation : Memory Tool Init [ v2.25 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 1723126C09A0515A6D7BBA6432507CE9 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 99595DE9FBC9A23C52E192196F1666FD93956B4DD68859369B94F540265B1B02 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_2 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100434A54443452049CF0BCBB972B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 434A54443452 EMMC: VEN : SAMSUNG : CJTD4R EMMC: SNN : 2633022651 ( 0x9CF0BCBB) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3247C7C2F4BFF75234045A0BB5FA192B DA : USB : HIGH-SPEED Boot done! Warning! Not found any mount point! If it blank IC - init GPT first! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Initialize PMT Initialize PMT from file : H:\Flash Files\Xiaomi\Redmi 9C\angelica_global_images_V12.0.14.0.QCRMIXM_20210604.0000.00_10.0_global_1a1e0de9da\angelica_global_images_V12.0.14.0.QCRMIXM_20210604.0000.00_10.0_global\images\MT6765_Android_scatter.txt PMT init FAILED! ERR : 0xC0040030 ERR : MMC ERROR ERR : 0x00004400|0x00004400 Operation finished! Close MemoryTool session Done! Elapsed: 00:01:09 Reconnect Power/Cable! |
The Following User Says Thank You to fahadboss For This Useful Post: |
07-09-2021, 16:02 | #8 (permalink) | |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Quote:
Code: Warning! Not found any mount point! If it blank IC - init GPT first! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Initialize PMT Initialize PMT from file : H:\Flash Files\Xiaomi\Redmi 9C\angelica_global_images_V12.0.14.0.QCRMIXM_20210604.0000.00_10.0_global_1a1e0de9da\angelica_global_images_V12.0.14.0.QCRMIXM_20210604.0000.00_10.0_global\images\MT6765_Android_scatter.txt PMT init FAILED! ERR : 0xC0040030 ERR : MMC ERROR ERR : 0x00004400|0x00004400 Operation finished! Close MemoryTool session | |
The Following User Says Thank You to yuranc8 For This Useful Post: |
