10-29-2015, 04:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | set dead after flash Set Came on hang on logo. Code: Operation : Check / Read Info [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 260 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040500A26936C1CB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A26936C1CB [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : D320 ProdModel : Micromax D320 Device : D320 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : D320 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_1_wg_n EXTRA : LCD [0] : ili9806e_fwvga_dsi_vdo_s857_6572 LCD [1] : #ili9806e_wvga_dsi_vdo_s833_6572 LCD [2] : nt35510_dsi_vdo_s833_kdw_6572 LCD Res : 854x480 TOUCH [0] : ft6206_s857 CAM [0] : gc2145mipi_yuv CAM [1] : gc0310_mipi_yuv CAM [2] : # CAM [3] : s5k4ecgx_mipi_yuv CAM [4] : s5k8aayx_yuv MODEM : s857_kk_hspa LOCALE : es_ES es_US en_US cs_CZ sk_SK hr_HR sl_SI pl_PL hu_HU zh_CN ru_RU hi_IN ru_RU fr_FR es_ES bn_IN ar_EG fa_IR en_GB Done! Elapsed: 00:00:14 Reconnect Power/Cable! Finish at : [10/27/2015 / 7:24:46 PM] Start at : [10/27/2015 / 7:25:03 PM] Operation : Read NVRAM [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 260 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040500A26936C1CB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A26936C1CB [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_1_wg_n Read Ok, MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_1_wg_n_eMMC.spnv saved Done! Elapsed: 00:00:35 Reconnect Power/Cable! Finish at : [10/27/2015 / 7:25:39 PM] Start at : [10/27/2015 / 7:25:51 PM] Operation : Format FileSystem [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 260 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040500A26936C1CB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A26936C1CB [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! Finish at : [10/27/2015 / 7:26:13 PM] Scatter Load Ok , BaseBand : MT6572 , Project : s857_72_kk , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Start at : [10/27/2015 / 7:37:36 PM] Operation : Flash [ v1.35 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 260 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040500A26936C1CB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A26936C1CB [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s857_72_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3585 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000A16C0000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s857_72_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:32 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:27 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:34 Reconnect Power/Cable! Finish at : [10/27/2015 / 7:42:05 PM] |
10-29-2015, 05:03 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: bhopal
Member: 1778370 Status: Offline Sonork: sujan_goa Thanks Meter: 66 | Quote:
The Following User Says Thank You to p.k510 For This Useful Post: |
10-29-2015, 05:30 | #3 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,213 | Quote:
10-29-2015, 05:36 | #4 (permalink) |
Junior Member Join Date: Sep 2015 Location: PHALTAN INDIA
Member: 2466072 Status: Offline Sonork: 16694115 Thanks Meter: 9 | naad type cpu use same vergin flash file http://forum.gsmhosting.com/vbb/f781.../#post11294442 use this strick |
10-29-2015, 06:00 | #6 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,213 | Check HW Ver & flash correct FW : V1 : http://forum.gsmhosting.com/vbb/11277869-post5.html V2 : http://forum.gsmhosting.com/vbb/11275922-post3.html |
