Old 03-11-2010, 09:43   #1 (permalink)
Member: 30124
Sonork: 100.1590000
Thanks Meter: 7,900
Question Alcatel unlocked But Not in the List of Shell
Dear team Infinity, just wanted to divert your attention to one miner bug in the shell, Vodafone 541 also known as Also known as Alcatel OT-708, which is not in the list of infinity shell.
Set is unlocked by infinity though but please add it in the list under shell:-
COM3 [VCP2] selected
module v3.23
Device: Vodafone-541
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:8503:A00D
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.93583 B3E.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
rom info detection finished
device-id: 93583B3E
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID is absent
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization: XN17FB75
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35400703337001
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_93583B3E_E8F450A0_20100311-114709.B0X.bin
Finished, time used: 4 min 12 sec
Remove/Install battery now !
The Following User Says Thank You to Yashaka For This Useful Post:
Old 03-11-2010, 09:55   #2 (permalink)
agadir5241's Avatar
Member: 771019
Thanks Meter: 27
vodafone 541 is in the latest shel v_1.35 brother
Old 03-11-2010, 09:57   #3 (permalink)
Member: 30124
Sonork: 100.1590000
Thanks Meter: 7,900
Please read my post and then post comment, i just requested team to add OT-708 in the list, i know 541 is in the list and set is also unlocked if you can read the log,
Old 03-11-2010, 22:26   #4 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Alcatel-708 model exist in Shell and in MModule list. (see Alcatel-708 model, not Alcatel OT-708).
Airtel Cordless FGD_9000 not in the list ajit bs Infinity-Box 3 03-31-2010 13:21
Can i unlock LG GB250 , is not in the list but to select another model? svchost Z3X-Team Products 12 12-11-2009 22:41
Alcatel OT-E220 unlocked and not on the list!! ::: Already in List., LOOK WELL ::: BackSlash_cu PolarBox 3 9 08-06-2009 18:22
I install firmaware but in the listing of the DTC4 in Products does not appear 1112 engels n-Box 0 06-16-2009 00:16
Page generated in 0.17742 seconds with 9 queries
