09-05-2009, 14:13 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | sigmatel can,t flashed help COM5 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CB03:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20090905-133847.B0E.bin flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: EC257E25082501:FFFFFF00000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 detect device identification#2 finished Write Fail Finished, time used: 527 sec Remove/Install battery now ! |
how can i flash vodafone 541....[SOLVED] | lad2 | PolarBox 3 | 3 | 03-29-2010 18:49 |
7210c How can i flash [help cuclone team] | gsmTECHNICIAN | Cyclonebox | 1 | 09-14-2009 06:48 |
S7330 phone lock password-CAN NOT FLASH-HELP | zonetrichur | UST Pro II | 3 | 08-08-2009 16:54 |
k850i can not flash help me | dauyeuqn | Sony Ericsson | 3 | 06-29-2009 08:05 |
6610 can erase but can not flash help!! | NuengEve | UFS2 + UFS3-Tornadoflasher | 1 | 03-07-2005 19:14 |
