Sigmatel FXD s90i i need the flash file of Sigmatel FXD s90i GEMINI_PCB01_GPRS_MT6225_S00.EDS5227ML_MA_RDA_ST_0 306.BIN ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:DD03:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.3.01, database date: 30.11.2009): GEMINI_PCB01_GPRS_MT6225_S00.EDS5227ML_MA_RDA_ST_0 306.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: GEMINI_PCB01_GPRS_MT6225_S00.EDS5227ML_MA_RDA_ST_0 306.BIN ver. sw 2: EDS5227ML_MA_RDA_ST_0306, 00000000 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GEMINI_PCB01_GPRS_MT6225_S00.EDS5227ML_MA_RDA_ST_0 306__fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GEMINI_PCB01_GPRS _MT6225_S00.EDS5227ML_MA_RDA_ST_0306__fullflash_20 091214-134219.B0M.bin Finished, time used: 898 sec Remove/Install battery now ! |
hello! must be very rare or new firmware. unfortunately we dont have it in our collection. you can try to search for same working phone on local market. read out full backup and use it for flashing your faulty phone. also i can convert to infinity format BIN file, if you find it. by the way, did you try to solve your problem without flashing, just by format FFS/IMEI restore? |
hello! yes, and unfortunately we dont have it in our collection. you can try to search for same working phone on local market. read out full backup and use it for flashing your faulty phone. also i can convert to infinity format BIN file, if you find it. |
Any body help me urgent Sigmatel S90i flash file MTK6225 16MB Project ID: EDS5227I_ML_MS20_AR_ST_0227 |
