Old 05-15-2010, 14:17   #1 (permalink)
Member: 383211
Thanks Meter: 131
nokia 6700i need pinout help
i try to find china nokia 6700 pinouts.but i never find it.plz check the follwing pic and give me pinouts
Old 05-15-2010, 18:40   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what type connector is used? your picture is not clear
Old 05-16-2010, 08:03   #3 (permalink)
Member: 383211
Thanks Meter: 131
hello!
i attached the conector type plz check
Old 05-16-2010, 16:24   #4 (permalink)
Member: 148515
hello!
how many pins? 5?
how many rows 1 or 2?b
Old 05-16-2010, 16:36   #5 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi..
try this.. u have to made cable...
Old 05-17-2010, 05:12   #6 (permalink)
Member: 383211
Thanks Meter: 131
hello!
how many pins? 5?
i row and 5 pins conector
Old 05-21-2010, 08:12   #7 (permalink)
Member: 148515
hello!
most 5pin connector phones do not keep tx/rx in system connector.
you must search for test points on PCB.
i can teach how to examinate them by multimeter
Old 05-23-2010, 15:48   #8 (permalink)
Member: 383211
Thanks Meter: 131
hello!
ok but i check this conector carefully there is 5 pin up and 5 pin down.and plz tell me how search pinout on pcb.
Old 05-24-2010, 08:33   #9 (permalink)
Member: 148515
hello!
you must attach phone battery, power On phone.
and next measure voltages on all available test points or even system connnecotr pins.
when you see 2,7-2,9 volts- those will be Tx/Rx
Old 06-06-2010, 22:41   #10 (permalink)
Member: 1194696
Red face China Nokia 6700
Hello!
Pls. somdebody help me to connect my China Nokia 6700.I'm totaly confused. Only connector which is suitable for it is from infinity pinfinder is cable "L5A". But pin finder can't detect pinout. As I understand from previouse posts. This connector type don't have RX & TX pins. So I should connect directly to main board? If yes pls. give somebody detailed description how to do it and what is next step to flash this phone using China Miracle from infinity. This is realy my favoride BOX. Hope for somebody assistance. Here is some links to pictures:
Old 06-07-2010, 10:56   #11 (permalink)
Member: 148515
hello!
you are absolutely right, now you must disessemble phone and find test points.
here is example how this must be done:
http://forum.gsmhosting.com/vbb/5530460-post2.html
but first please make sure that your phone is MT62xx family phone.
otherwise this method will not work
Old 06-07-2010, 13:25   #12 (permalink)
aco
aco's Avatar
Member: 18927
Thanks Meter: 36
This is pinout but I can't read that phone with infinity.MT6226BA
Old 06-07-2010, 20:59   #13 (permalink)
Member: 148515
hello!
here is common mistakes:
1. do not forget to connect box RJ45 pin 8 with phone grounded part.
2. phone TX must be connected with box RX and otherwise RX with TX.
(not TX+TX, RX+RX!)
Old 06-08-2010, 08:35   #14 (permalink)
aco
aco's Avatar
Member: 18927
Thanks Meter: 36
OK. Thank you
Old 06-08-2010, 18:54   #15 (permalink)
Member: 148515
hello!
i will make myself more clear:
Tx point must go to box RJ45 pin number 3
Rx test point goes to pin 2 of RJ45
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.29886 seconds with 10 queries
