Old 06-05-2010, 13:05   #1 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Sigmatel not celebrated >>
Hi ,
got mobile of sigmatel problem is when ever we try to power on its say not celebrated on LCD ,
i had tried all things which i can , but still same problem , here i am giving you link for that flash file , please check it thanks
PHP Code:
http://rapidshare.com/files/395533346/T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash_20100605-151603.B0M.bin
==== [6/5/2010 2:56:34 PM] ====
COM3 [VCP0] selected
module  v3.14
Action: touchscreen calibration
mode: 2
Calibration order: reverse
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1003:0002
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: T600_V04_EnFrArRuSpPeVi_SIGMATEL
Version: T600_V04_HW
detecting structure #2...
 5 11 done
67 byte(s) read
imei: 35798632542412
connection Ok
detecting structure #5 (mode-2)...
 18 17 done
210 byte(s) read
reading data #2...
512 byte(s) read
calibration value: 0
writing data...
verification...
verification Ok
Power-On and test phone now
If calibration is not completed yet:
1. make "Reverse calibration order" UN-checked and try again
2. try another calibration mode
Finished, time used: 41 sec
Remove/Install battery now !
==== [6/5/2010 2:57:34 PM] ====
module  v3.14
mode: 3
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-3)...
 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error:
detection failed (20 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't detect ffs/eeprom structure id
error: operation failed !
Finished, time used: 14 sec
==== [6/5/2010 2:57:58 PM] ====
module  v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-4)...
What to do:
3. Power-On phone
Finished, time used: 12 sec
==== [6/5/2010 2:58:22 PM] ====
module  v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-1)...
 1 4 5 6 done
211 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
1. make "Reverse calibration order" Checked and try again
==== [6/5/2010 2:58:53 PM] ====
module  v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
 19 18 done
147 byte(s) read
reading data #2...
reading data #3...
can't read required data
Finished, time used: 25 sec
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== [6/5/2010 2:59:37 PM] ====
module  v3.14
Device: Autodetect 6205-6239 NOR
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====>  Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL.BIN
project-id: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 48 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== [6/5/2010 3:01:10 PM] ====
module  v3.14
mode: 3
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0error:
What to do:
3. Power-On phone
Finished, time used: 54 sec
==== [6/5/2010 3:02:23 PM] ====
module  v3.14
mode: 2
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
 18warning: wrong packet cs
 17 done
210 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 15 sec
==== [6/5/2010 3:02:55 PM] ====
module  v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
 19 18 done
147 byte(s) read
reading data #2...
reading data #3...
Finished, time used: 22 sec
==== [6/5/2010 3:03:26 PM] ====
module  v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
 1 4 5 6 done
211 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
==== [6/5/2010 3:03:57 PM] ====
module  v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
Finished, time used: 11 sec
==== [6/5/2010 3:04:18 PM] ====
module  v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
 5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
==== [6/5/2010 3:04:40 PM] ====
module  v3.14
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
aborted by user
Finished, time used: 7 sec
==== [6/5/2010 3:04:54 PM] ====
module  v3.14
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash...
file saved: C:\Documents and Settings\Faisal Hussain\My Documents\T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash_20100605-151603.B0M.bin
Finished, time used: 11 min 15 sec
==== [6/5/2010 3:16:17 PM] ====
module  v3.14
Loading file v.02...
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash_20100605-151603.B0M.bin loaded
ffs/eeprom record offset detected
ffs/eeprom record size detected
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
512 byte(s) read
211 byte(s) read
1748 byte(s) read
writing data...
verification...
error: verification failed
what to do:
1. be sure that you have full flash backup for emergency case
2. make "format ffs" in "complete" mode
3. power-on phone
4. power-off phone by "Power" button (DO NOT remove battery)
5. repeat current operation
==== [6/5/2010 3:17:00 PM] ====
module  v3.14
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
512 byte(s) read
211 byte(s) read
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 17 sec
==== [6/5/2010 3:17:51 PM] ====
module  v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
 19 done
211 byte(s) read
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 10 sec
==== [6/5/2010 3:18:13 PM] ====
module  v3.14
mode: 2
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
 18 17 done
210 byte(s) read
512 byte(s) read
writing data...
verification...
verification Ok
==== [6/5/2010 3:18:35 PM] ====
module  v3.14
mode: 3
19200 autodetect
Initializing [6225:8A05]...
CPU: MT6225
high speed boot On
chip: 0000:0000:0000
status: 18
error: initialize step #1 failed
Can not initialize test mode, possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method
==== [6/5/2010 3:18:54 PM] ====
module  v3.14
mode: 3
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
==== [6/5/2010 3:19:21 PM] ====
module  v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
==== [6/5/2010 3:19:51 PM] ====
module  v3.14
Action: repair security area
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
detecting startup code area #2...
startup code area #2 is absent
sec info (fast) detection...
error: incorrect ffs address range
Finished, time used: 1 min 23 sec
==== [6/5/2010 3:21:25 PM] ====
module  v3.14
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
building list...
done
items to clear: 135
items cleared: 135 of 135
building list...
done
items remains: 0
Faisal_Computer
Old 06-05-2010, 13:08   #2 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
just write eprom file ur problem will solve
wb
stan1comm
Old 06-05-2010, 13:31   #3 (permalink)
Member: 151871
can any one confirm
Faisal_Computer
Old 06-06-2010, 06:05   #4 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
Originally Posted by Faisal_Computer View Post
can any one confirm
Faisal_Computer
make full flash backup then do format ffs complete .........then do tuch screen calebration in auto mode whan ask backup give it saved backup ....100% tested
Old 06-06-2010, 07:28   #5 (permalink)
Member: 151871
already tried !!
Faisal_Computer
Old 06-07-2010, 10:40   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
already tried !!
Faisal_Computer
hello!
can you post a log of that operation?
Old 06-07-2010, 18:43   #7 (permalink)
Member: 151871
hello!
already in 1st post
Old 06-07-2010, 21:16   #8 (permalink)
Member: 148515
hello!
sorry, i did not check that window carefully.
please try this flash file:
flashfiles/ChineseMiracle/_MT6225/eeprom/T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88_eeprom_for_not_calibrated.B0E.bin
Old 06-08-2010, 14:24   #9 (permalink)
Member: 151871
hello!
ok today i will do and post you results
Faisal_Computer
Old 06-08-2010, 15:01   #10 (permalink)
Member: 151871
hello!
module  v3.14
Action: write flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__Sigmatel-s88_eeprom_for_not_calibrated.B0E.bin
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
====>  Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
usb bootloader (file) is absent
Write Done
Finalization Done
Finished, time used: 1 min 52 sec
before writing this eeprom mobile problem was when every power on the mobile on the screen(i never seen before just 1st time i ever seen) big sized text appear "Not Celebrated" after writing this eeprom mobile say screen not celebrate etc etc like normal saying for celebration then i again try to celebrate with normal way 1st i do from one to four but did not help then i do with reverse option four to one at last reverse with one method its works and now mobile working normal
once thanks to infinity team for their Great Work !!
wish you long live
Faisal_Computer
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
hope it is not too comercial aleksj Wanted Products 0 06-12-2000 13:22
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2000 22:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 0.34016 seconds with 9 queries
