Old 08-15-2008, 16:50   #1 (permalink)
bhogpurmail's Avatar
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
sigmatel s1 dead after flash
Hi,,
I have a sigmatel s1 in hang condition.
i flashed it (file taken from supprt area)
but phone goes dead condition........
unfortunate, i miss it's backup.....(coz windows corrupt)
so, i need help
plz give me a working flash file for it
my phone detail s
CPU type:- MT6225
Flash type :- K5L2731CAA
Charging jeck:- 1X12 pin(L12C cable use in pinfinder)
Pinouts RX-6,TX-7
Plz help, it's very urgent..
Also Attached the log of last flashing :-
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
enhanced security fix enabled
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:0E03:0009
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18A59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080815-170827.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 2098 sec
Remove/Install battery now !
Old 08-15-2008, 21:33   #2 (permalink)
Member: 148515
Thanks Meter: 19,253
hello!
try all of them
flashfiles/ChineseMiracle/Sigmatel/GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1_0_017_080226_Sigmatel-S1_En_Fr_Vn_Ru_Ar_Th.B0M.bin
flashfiles/ChineseMiracle/Sigmatel/GINWAVE25_06B_PCB01_GPRS__MT6225_S00.FXD-S1-ML_MR106_004_5S02-MC-C01-RF3198_V1_1_023_080409__Sigmatel-S1_16m_En_Ru_Fr_Th_Vn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6225/GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1_0_017_080226_Sigmatel-S1_En_Fr_Vn_Ru_Ar_Th.B0M.bin
Old 08-16-2008, 06:30   #3 (permalink)
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
sir, itry all file already... but not success
Old 08-16-2008, 07:58   #4 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Did u backup the original firmware before flash . . . ?
If YES then write this backup file on the phone.
& try to power on the phone.
Post result.
Old 08-16-2008, 08:17   #5 (permalink)
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
Old 08-16-2008, 09:51   #6 (permalink)
Member: 148515
hello!
i think your phone was another version.
can you check operation.log for first operation which you did with this phone?
you will see there it's original version
Old 08-16-2008, 12:48   #7 (permalink)
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
sir, my window's corrupted , so it's not possible to get any log after re-installetion
Old 08-16-2008, 17:56   #8 (permalink)
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
plz share working file, if anyone have it.........
Old 08-17-2008, 09:39   #9 (permalink)
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
helo supporter,
i arrange same version flash file
it's possible to flash it after format complete whole flash chip.........
reply soon.........
th***
Old 08-17-2008, 14:18   #10 (permalink)
Member: 148515
hello!
write backup from working phone to your dead set.
all will be ok
Old 08-17-2008, 14:27   #11 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,910
first format : whole flash chip &
second : flash with this file
Old 08-17-2008, 18:01   #12 (permalink)
Member: 189506
Sonork: 100.1576871
Thanks Meter: 126
FLash error during write the backup flash file
write: Firmware
skip: Customization
write: Eeprom/ffs
Boot...
19200 autodetect
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
flash: EC257E25082501:FFBFFF00000000
Initialize Done
Set baud...
115200
Set baud Done
it's time to stop: FFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBF
.damaged firmware
.damaged hardware
warning: optional information is not found,
ffs chip: 00
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080817-222124.B0E.bin
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
error: error# 000000FF
error: flash write error: 00000000:00002000
2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BF82E3B3B3BFC 2E3B3B3B7E2E3B3B3BFC2E3B3B3BFC2E3B3B3BB02E3B3B3B7E 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BDC2E3B3B3BB62E3B3B3B1D2E3B3B3B282E3B3B3BBC 2E3B3B3BFC2E3B3B3B032E3B3B3B022E3B3B3BFC1A1A2E3B3B 3BFC2E3B3B
error: unexpected termination/freez: 00000000
Write Fail
Finished, time used: 881 sec
Old 08-17-2008, 21:54   #13 (permalink)
Member: 148515
hello!
i think you must resolder flash IC or at least heat it
looks like Flash IC bad soldering
Old 08-17-2008, 22:04   #14 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
sigma tell s1
i wantto help u
so pm with me on yahoo my id [email protected]
Old 08-17-2008, 22:08   #15 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
pm with me [email protected]
sigmatel s90 dead after code...... ^^^RAVI SOOD^^^ Infinity-Box 3 04-12-2009 09:17
sigmatel s1 dead plz help subra007 Infinity-Box 4 03-09-2009 12:32
sigmatel s98 dead after code *#33646633# dakku Chinese Models & Cloned Phones 0 03-07-2009 16:42
sigmatel s1 dead by format jitugrover SpiderMan 5 09-21-2008 14:34
sigmatel s1 dead jitugrover Chinese Models & Cloned Phones 2 08-08-2008 12:24
Page generated in 0.23896 seconds with 9 queries
