sigmatel s90i need magic voice option i have sigmatel s90i but magic voice option not there so now i need that option so which files want to be selected to flash for that option |
hello! let us know your phone's original software version. also make full back. |
COM3 [VCP1] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CD03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #03 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #04 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #05 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #06 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #07 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.CB418A2C.[GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.S90+_083 2_TS64X32_V001.BIN_04DAB0C3].rpl rom info detection finished device-id: CB418A2C rom info ver: 05 sw version: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.S90+_083 2_TS64X32_V001.BIN project-id: S90+_0832_TS64x32_V001, C3B0DA04 code offset: 00000000 ffs offset/size [01]: 00770000/00090000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00770000 flash: 98009600000000:2BEA0000000000 checking area [00000000]: 00080000-007FFFFF... ffs/eeprom found near: 00330000 Detected ffs/eeprom address is non-standard: 00330000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00330000 detecting ffs/eeprom size... ffs/eeprom size: 004D0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00330000-007FFFFF firmware area: 00000000-0032FFFF detecting ffs/eeprom structure pass 1... ............. ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.S90+_083 2_TS64X32_V001.B detecting firmware build... ............................ firmware date/time: 2009-06-12 15-26 hw1: PCBA_V3.1 hw2: MAUI_GINWAVE25_08A_GEMINI done detecting product-id... ................................ done detecting languages... .......................... language parameters detected detected languages: En Ru Fr Vn Hi Farsi Ar file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.S90+_0832 _TS64X32_V001.B__system_log_CB418A2C_04DAB0C3_2010 1112-101715.B0X.bin Finished, time used: 1 min 9 sec Remove/Install battery now ! then that is backup below GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.S90+_083 2_TS64X32_V001__fullflash_20101112-095535.B0M.bin pls give a good solution for need magic voice |
hello! try this flash file: flashfiles/ChineseMiracle/_MT6225/GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.S90+_083 2_SANSUNG64X32_V004__w_eeprom_8m_En_Ru_Fr_Vn_Hi_Fa rsi_Ar.B0M.bin does it have Magic voice option? |
thanks to help |
hello! try this one: flashfiles/ChineseMiracle/_MT6225/8m/GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.S91_0832 _SAMSUNG64X32_V006_8m_En_Ru_Fr_Vn_Hi_Farsi_Ar.B0M. bin |
hello! unfortunately, we dont have other firmwares for Sigmatel S90 |
this is right file GEMINI_PCB01_GPRS_MT6225_S00.EDS5227I_ML_FC_RDA_ST _0310_1__fullflash_20101125-041955.B0M |
hello! sorry, posted link is not downloadable |
thank you! will upload it to support for future use |
