Old 04-17-2008, 16:15   #1 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
Trend T500 Dual Sim Succesfully Repaired
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8A01]...
CPU: MT6219
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom]...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80417-200612.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 126 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-17-2008, 18:05   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
thank you for this test report!
Old 05-01-2008, 16:21   #3 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
Which Pinouts do u use for T500..
can u post it here???
Old 05-01-2008, 19:30   #4 (permalink)
Member: 148515
hello|!
use "search" buton in this forum
http:///vbb/showth...ght=trend+t500
Old 07-21-2008, 16:42   #5 (permalink)
Member: 199814
Thanks Meter: 1,960
I have flashed that model on both pinouts searched by pin finders but there is an strange issue the logo of startup on phone is being repeated again and agains kindly help me...
Old 07-21-2008, 23:26   #6 (permalink)
Member: 148515
hello!
format FFS in first phone part (mt6226 CPU)
Old 07-22-2008, 09:45   #7 (permalink)
Member: 199814
Thanks Meter: 1,960
hello!
I have done that activity before this post but issue is still same FFS Complate formated on both sides...
here is log
==== log opened: [7/21/2008 9:12:56 AM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe
Loading data, wait...
[Infinity Box] v2.51
S/N: 4389:010F
Wait...
Done
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
COM5 [VCP0] selected
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:BD41:05E4
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Initialize Done
Set baud...
slowest
Set baud Done
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: X6_PCB02_GPRS_MT6226_S01.X6_PK_ENGLISH_06_12_9320_V1_39.BIN
ver. sw2: X6_PK_English.06.12.9320.V1.39, 00000000
ffs offset/size: 00E00000/00200000
standard eeprom/ffs offset detected: 00E00000
ffs chip: 00
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 66 sec
Action: read information
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
baud set to: 19200
error: connection failed !
Operation failed !
Finished, time used: 11 sec
Power off phone now !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
ffs chip: 00
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat location pass #2...
detect extended fat location pass #2...
detect standard fat offset pass #2...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
detect extended fat location pass #1...
ffs element #2 detected ok
Finished, time used: 88 sec
Action: repair security area
Boot...
error: can't detect device
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 4 sec
Action: touchscreen calibration
error: can't activate test moide
error: operation failed !
Finished, time used: 7 sec
19200 autodetect
CPU: MT6226
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: X6_PK_English.06.12.9320.V1.39
Version: X6_MT26_05C_HW_PCB02
detecting structure #2...
 done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is wrong !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5...
 0 1 done
204 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 13 sec
Boot...
Boot Fail
Finished, time used: 10 sec
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
Write...
Write Done
Finalization...
Finalization Done
Finished, time used: 43 sec
Old 07-22-2008, 17:57   #8 (permalink)
Member: 148515
hello!
you said you flashed it.
what was phone original software version and which files did you use for flashing?
Old 07-23-2008, 11:54   #9 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
here is log
S/N: 4389:010F
Wait...
Done
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
ffs chip: 00
Write...
Write Done
Finalization...
formatting...
Finalization Done
Connecting, wait...
baud set to: 19200
Operation failed !
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
ffs chip: 00
Boot...
Boot Fail
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
 done
60 byte(s) read
connection Ok
 0 1 done
204 byte(s) read
writing data...
verification...
verification Ok
Boot...
Boot Fail
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
Write...
Write Done
Finalization...
Finalization Done
Make sure u formatted both CPU s ............
Old 07-24-2008, 09:59   #10 (permalink)
Member: 199814
Thanks Meter: 1,960
Not flashed just made misteek to say that but i have formated the fone.. so should i flash it? or what???
kindly help me
hello!
Old 07-24-2008, 10:00   #11 (permalink)
Member: 199814
Thanks Meter: 1,960
I am Sure Bhatti Sb. that i have formatted the phone from both cpus..
Old 07-24-2008, 11:04   #12 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
so wts the problem behind u r facing now????????????
Old 07-24-2008, 21:38   #13 (permalink)
Member: 148515
hello!
if formating do not help to get rid of restarting- need to flash phone
Old 07-25-2008, 08:20   #14 (permalink)
Member: 199814
Thanks Meter: 1,960
Write ... i am gonna try it now if will be done than update soon.
Old 07-25-2008, 09:48   #15 (permalink)
Member: 199814
Thanks Meter: 1,960
Any one kindly upload this firmware on any mirror site coz support not working fine with my slow connection 4 kbps ...
X6_PCB02_GPRS_MT6226_S01.X6_PK_ENGLISH_06_12_9320_ V1_39.BIN
trend T786 Dual Sim Set Problem HUM Various 6 08-22-2009 10:53
Need TREND T500 DUal SIm pinouts urgent mass_zoro Chinese Models & Cloned Phones 3 05-03-2009 16:54
..::Need TREND T500 DUal SIm pinouts::.. StRaNgE PeRsOn Chinese Models & Cloned Phones 5 01-03-2009 16:56
TREND T786 Dual Sim Succesfully Repaired .::BHATTI::. Infinity-Box 6 10-09-2008 13:00
---trend t500 dual sim second sim is not working any solution--- makkah mobile Infinity-Box 1 09-12-2008 09:26
Page generated in 0.32694 seconds with 9 queries
