11-12-2016, 14:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Yu yu5010 dead :- Code: Infinity-Box Qualcomm Module [QLM] v 1.02 Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0DAEE753 ID_BLOCK_I : 007050E1 ID_BLOCK_L : E8E33DA056360D64 ID_BLOCK_L : 7AEB673AA6EF3E4E Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! WBR sahil2000ind |
11-14-2016, 09:54 | #5 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | READ INFO Code: Infinity-Box Qualcomm Module [QLM] v 1.03 Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0DAEE753 ID_BLOCK_I : 007050E1 ID_BLOCK_L : FAD76BD8C3222710 ID_BLOCK_L : 803C0CE265CD195E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! FORMAT Code: Operation : Reset Settings [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0DAEE753 ID_BLOCK_I : 007050E1 ID_BLOCK_L : FAD76BD8C3222710 ID_BLOCK_L : 803C0CE265CD195E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:17 Reconnect Power/Cable! BUT PHONE STILL DEAD HOW TO FLASH PHONE NOT GOING IN FASTBOOT MODE ONLY EDL AND QUALCOM 9008 PORT SHOWING WBR sahil2000ind |
11-14-2016, 10:57 | #8 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | hi |
05-18-2017, 08:12 | #11 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | I can enter edl mode in this set through cable but there is a problem , qcom 9008 port shows exclamation mark when connected , any solution ? Set is on but restarting ... |
08-04-2017, 17:01 | #15 (permalink) | |
Freak Poster Join Date: Oct 2013
Member: 2043843 Status: Offline Thanks Meter: 39 | firmware issue. Quote:
You can check without selecting firmware file in flash tab ( use cm2 internal loader) it will work. | |
