skyzen ez500,, i need to restore the FS DATA I have one that by error i format the FS data when flashing,, ,how i can restore this .., now the phone working perfect but all screen are in white,.. any help support ? |
Hello, Do you have eeprom/ffs backup ? Eeprom backup should be created during any procedure, check files in MModule folder. Also post here operation log so we can see what is backup file name. |
this is the log file waiting for your help.. can i restore FS ??? ==== log opened: [14/03/2008 10:24:23] ==== Application: C:\Archivos de programa\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v1.69 S/N: 0533:010C Wait... Device: Skyzen EZ500 Done Loading file v.02... SkyZen-EZ500_SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLU S_W05_20_V48_En_Es.B0M.bin loaded protocol ver: 01 ver. sw1: SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN ver. sw2: SL308_PLUS.W05.20.V48 Languages: En Es Loading file v.02... SkyZen-EZ500_repair_eeprom_01.B0E.bin loaded COM5 [VCP0] selected Device: Skyzen EZ500 Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization skip: Language Pack write: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6218:8B04]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... detecting firmware version... .............................................. firmware version: SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BINS detecting languages... ............................. language parameters detected detected languages: En reading [eeprom[SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BINS]]... file saved: C:\Archivos de programa\InfinityBox\MModule\backup_eeprom[SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BINS]_20080314-102736.B0E.bin Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: B0001D00000000:B0001D00000000 Write: Firmware Area: Eeprom flash: B0001D00000000:B0001D00000000 Write: Eeprom formatting... flash: B0001D00000000:B0001D00000000 Write Done Finished, time used: 1035 sec Remove/Install battery now ! |
@humbedj I suggest you next time post more real problem description. Why you talk about "ffs format" but in fact you have flashed phone with firmware ? it's completely different operations ! Did you made full flash backup before flash process ? |
because is true,, I make a full flash to the phone,, and i stick ths FS format, now the phone wake up with withe screen but all phone work ok,, i need to restore the FS is posible support,, |
Hello, Let me ask one more time: did you made full flash backup before flash process ? |
not support i forget this important step,,, i have now a working phone but without image for format the FS .. any suggestion to put other FS ??? I don't see any FS or customization file in support any idea please? |
Hello, Please, explain what is "FS" ? What is the problem: you have flashed phone with firmware that is not good for your phone (don't have support for your phone LCD type). Now it's need to flash phone with another firmware that support your LCD type. You can try to flash phone with different files for Fly-MX200 and see results. Also, if you have another one EZ500 it's need to read flash from it and send to [email protected] |
i have problem with white screen after flash with support flashes in phone ez500, i flash with fly mx200 and work but say NO SERVICE and lenguage is russian and english only. I need spanish and unlock also... helpme please DC |
