05-05-2010, 20:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Juarez "Most Violent City" Age: 49
Member: 221355 Status: Offline Thanks Meter: 25 | Skyzen S3 Dead!!!! COM6 selected module v3.34 Device: Skyzen-S3 Checking data, wait... Action: write flash NAND write: Firmware SkyZen-S3_SLT100_TELCEL_PCB04_GPRS_MT6228_S02.MAUI_06A_W0 6_36_MP_V25_2007-06-20_H7.00R_En_Es_simfree.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: SLT100_TELCEL_BOOTLOADER_V005_MT6228_MAUI_06A_W06_ 36_MP_V25.bin nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.06A.W06.36.MP.V25 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: SLT100_TELCEL_BOOTLOADER_V005_MT6228_MAUI_06A_W06_ 36_MP_V25.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: SLT100_TELCEL_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_3 6_MP_V25.BIN project-id: MAUI.06A.W06.36.MP.V25, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: SLT100_TELCEL_BOOTLOADER_V005_MT6228_MAUI_06A_W06_ 36_MP_V25.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 2 loading files... number of areas: 2 done write... write bootloader... . write core... Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 7 min 21 sec Remove/Install battery now ! Phone does not power on and battery is full. After 15 seconds of pressing power button the keypad lights up for 5 seconds and nothing. I already full formated the phone. I try to unlock or write IMEI, but does not connect. Support, please advice. |
05-05-2010, 22:27 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Try to flash phone with another firmware, f.e. SkyZen-S3_SLT100_TELCEL_PCB04_GPRS_MT6228_S02.MAUI_06A_W0 6_36_MP_V48_2008-05-28_H7.06R_En_Es_simfree.B4M.bin Skyzen-S3_SLT100_SKZCRO_PCB04_GPRS_MT6228_S02.MAUI_06A_W0 6_36_MP_V48_2008-11-04_En_Es_Claro_simfree.B4M.bin What is the results ? |
05-06-2010, 00:27 | #3 (permalink) |
Member: 221355 Status: Offline Thanks Meter: 25 | I used another flash file: COM6 selected module v3.34 Device: Skyzen-S3 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.06A.W06.36.MP.V25 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: SLT100_TELCEL_BOOTLOADER_V005_MT6228_MAUI_06A_W06_ 36_MP_V25.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: SLT100_TELCEL_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_3 6_MP_V25.BIN project-id: MAUI.06A.W06.36.MP.V25, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 37 sec Remove/Install battery now ! Same. No response. |
05-06-2010, 12:25 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, If phone still can not power-on well, it may be some kind of firmware <-> hardware incompatibility. Do you have original full flash backup ? You can try to flash phone with another firmware files, f.e. Fly-SX210 or Fly-SLT100 firmware files. Also, are you sure that this phone was well working before flash ? |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
