10-18-2015, 09:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2015 Location: pakistan
Member: 2373427 Status: Offline Thanks Meter: 43 | Mtk 6260 after formate invalid imei can u add imei repair option? log 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 8C31E7B96091124129883DDE3553670E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00DE0000-0x00FFFFFF , LEN : 0x00220000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
