12-20-2015, 12:10 | #1 (permalink) |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,578 | smart av every time say removed but again scan same condition 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303847453001DA18B5F212F3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG80 [eMMC] : FLASH_CID : 11010030303847453001DA18B5F212F3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictonary Collect done : 0x0006 [DDCleaner Info] : Files to remove : 7 [DDCleaner Info] : Additional garbage detected : 1 Removing files ... [DDCleaner] : Removed 7 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:02:06 Reconnect Power/Cable! |
12-20-2015, 12:14 | #2 (permalink) |
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,578 | after remove again check same result Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303847453001DA18B5F212F3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG80 [eMMC] : FLASH_CID : 11010030303847453001DA18B5F212F3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictonary Collect done : 0x0006 [DDCleaner Info] : Files to remove : 7 [DDCleaner Info] : Additional garbage detected : 1 Removing files ... [DDCleaner] : Removed 7 Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:02:22 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to vishnudatt For This Useful Post: |
12-20-2015, 12:35 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Switch on phone and check in app manager whether apps are still there or removed. Br. Infinity Box Support Team. |
12-20-2015, 12:52 | #4 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | yes also face same problem with me please fix this problem Lava iris 504Q+ remove all think but still come virus again & again Code: Start at : [12/20/2015 / 11:31:23 AM] Operation : Scan APPs [DDirect] [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201B7C9C80811A1 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201B7C9C80811A1 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictonary Collect done : 0x0004 [DDCleaner Info] : Files to remove : 4 [DDCleaner Info] : Additional garbage detected : 0 Removing files ... [DDCleaner] : Removed 4 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:41 Reconnect Power/Cable! Finish at : [12/20/2015 / 11:32:04 AM] Code: Start at : [12/20/2015 / 11:29:24 AM] Operation : Scan APPs [DDirect] [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201B7C9C80811A1 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201B7C9C80811A1 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait [User Select] : Remove Files and Garbage , Update Dictonary [DDCleaner Info] : Files to remove : 0 [DDCleaner Info] : Additional garbage detected : 0 [DDCleaner Info] : Dictonary Update Ok! Removing files ... [DDCleaner] : Removed 0 Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! Finish at : [12/20/2015 / 11:30:17 AM] Code: Start at : [12/20/2015 / 11:29:24 AM] Operation : Scan APPs [DDirect] [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201B7C9C80811A1 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201B7C9C80811A1 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait [User Select] : Remove Files and Garbage , Update Dictonary [DDCleaner Info] : Files to remove : 0 [DDCleaner Info] : Additional garbage detected : 0 [DDCleaner Info] : Dictonary Update Ok! Removing files ... [DDCleaner] : Removed 0 Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! Finish at : [12/20/2015 / 11:30:17 AM] Code: Chinese Miracle II [MTK module] v 1.39 Start at : [12/20/2015 / 11:14:03 AM] Operation : Scan APPs [DDirect] [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201B7C9C80811A1 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201B7C9C80811A1 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictonary Collect done : 0x0004 [DDCleaner Info] : Files to remove : 4 [DDCleaner Info] : Additional garbage detected : 0 Removing files ... [DDCleaner] : Removed 4 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:45 Reconnect Power/Cable! Finish at : [12/20/2015 / 11:14:49 AM] Code: Start at : [12/20/2015 / 10:38:42 AM] Operation : Remove Viruses [SmartAV] [ v1.39 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201B7C9C80811A1 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201B7C9C80811A1 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 60 Removing infected files and scripts ... SmartAV Report : Removed 60 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:01:27 Reconnect Power/Cable! Finish at : [12/20/2015 / 10:40:09 AM] please JayDi Sir Fix This problem Soon As Soon |
The Following User Says Thank You to Momin_Telecom For This Useful Post: |
12-20-2015, 13:22 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | http://server1.infinity-box.com/down...APP_Remove.pdf read carefully at least once or more time 100% ur all problem solve again say read manual once |
12-20-2015, 13:29 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Just delete CM2. Get something other and fu*ck their brains. Leave me, I tired. I REALLY TIRED SAY AGAIN AND AGAIN SAME THINGS THOUSAND TIMES! |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
12-21-2015, 17:58 | #12 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Sorry for this "FIGHT"... @VISHNUDATT... for me the BEST tool is CM2 to remove App and Viruses.... Never FAIL!!!!!! Please REMEMBER after use Smart_AV you do "FULL FACTORY".. Please TRY again.... |
