01-25-2021, 22:31 | #167 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2471057 Status: Offline Thanks Meter: 0 | Your question: Why do you use visual studio debugger with Infinity software ? My answer : I didn't use the visual studio debugger with Infinity software. Accidentally possible. And I explained to you what I do with visual studio. and excuse me i don't speak english this is from google traduction |
01-25-2021, 22:56 | #168 (permalink) | |
Debugger usage is not allowed with Infinity software. Now you can update dongle firmware. It is LAST time we do this. If you will have the same issue again it will be NO EXCEPTION any more. Thank you for your kind cooperation ! | |
01-25-2021, 23:16 | #169 (permalink) | |
Member: 2471057 Status: Offline Thanks Meter: 0 | Quote:
Thanks but this is a big problem I mean, a special computer must be created for development | |
01-26-2021, 04:27 | #172 (permalink) |
Freak Poster Join Date: Nov 2016 Location: Vietnam
Member: 2643704 Status: Offline Sonork: Zalo:0932606079 Thanks Meter: 135 | === DongleManager [Infinity] v1.81 [26/01/2021 10:25:22] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000079A13E64082 === Process started: 26/01/2021 10:25:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 === DongleManager [Infinity] v1.81 [26/01/2021 10:25:22] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000079A13E64082 === Process started: 26/01/2021 10:25:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
01-26-2021, 04:27 | #173 (permalink) |
01-26-2021, 04:45 | #176 (permalink) |
Junior Member Join Date: Jul 2013 Location: ไทย
Member: 1970395 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.81 [26/1/2021 10:42:47] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00007B4413114082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 7EA97B44 Firmware version: 0147.02 === Process started: 26/1/2021 10:42:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-26-2021, 05:35 | #177 (permalink) |
Member: 1970395 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.81 [26/1/2021 11:21:56] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000FDF813114082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 9758FDF8 Firmware version: 0147.02 === Process started: 26/1/2021 11:21:58 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 After updating My friend has a problem as well. |
01-26-2021, 05:37 | #178 (permalink) | |
Member: 1970395 Status: Offline Thanks Meter: 1 | Quote:
My friend has a problem as well. | |
01-26-2021, 05:39 | #179 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2464630 Status: Offline Thanks Meter: 0 | How to fix can't update firmware === DongleManager [Infinity] v1.81 [2021-01-26 11:16:27] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00011A5913114082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 9ACB1A59 Firmware version: 0147.02 === Process started: 2021-01-26 11:16:29 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
01-26-2021, 05:50 | #180 (permalink) |
No Life Poster Join Date: Oct 2007 Location: in your hert
Member: 618615 Status: Offline Thanks Meter: 85 | = DongleManager [Infinity] v1.81 [1/26/2021 9:49:26] === Searching... Card-Reader: FT SCR2000 0 HWID: 020099891D041292 Box/Dongle found: Infinity [BEST] Serial No (S/N): 21669989 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle [CM2] v0147 - 03: Infinity [BEST] v0122 - 07: #7 => Options: - Infinity [BEST] - Infinity [BEST2] - Infinity SM |
