Old 01-27-2021, 20:57   #286 (permalink)
Member: 31028
Thanks Meter: 56
solved, many thx
regards
The Following User Says Thank You to [Rod] For This Useful Post:
Old 01-27-2021, 23:51   #287 (permalink)
Member: 2534813
Thanks Meter: 18
the last update block my card
why?
=== DongleManager [Infinity] v1.80 [27/01/2021 16:48:59] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0002C53B00001942
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): A3BDC53B
Firmware version: 0146.02
=== Process started: 27/01/2021 16:49:02 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0006] Your account is temporary suspended.
See problem reason in log file
Contact to http://www.infinity-box.com/support/?r=2
Old 01-27-2021, 23:53   #288 (permalink)
Member: 2534813
Thanks Meter: 18
=== DongleManager [Infinity] v1.80 [27/01/2021 16:47:24] ===
Searching...
Reading...
=== Process started: 27/01/2021 16:47:28 ===
Authentication successfull
Service stage 1 confirmed
Securing session...
Error securing session:
Server answer:[0036] Smart-Card Keys fault (Smart-Card can not be updated).
In most cases it's a Hardware fault or harmful software activity !
Old 01-27-2021, 23:53   #289 (permalink)
Member: 148515
Thanks Meter: 19,534
why?
Reading...
because your have used low-quality card-reader or drivers was not installed.
do you have another reader ?
Old 01-28-2021, 00:00   #290 (permalink)
Member: 2534813
Thanks Meter: 18
yes i have a another reader, but version InfinityBox_install_CM2MT2_v2.16 work ok
new version not!
Old 01-28-2021, 00:09   #291 (permalink)
Member: 148515
new version not!
insert card into other card reader now
and update card ONLY ONCE
Old 01-28-2021, 02:44   #292 (permalink)
Member: 2979355
=== DongleManager [Infinity] v1.81 [1/28/2021 8:41:17] ===
Searching...
Card-Reader: USB CCID Smart Card Reader 0
HWID: 0000048818434082
Box/Dongle found: Infinity-Box/Dongle [CM2]
Reading...
Serial No (S/N): 4BE70488
Firmware version: 0147.02
=== Process started: 1/28/2021 8:41:30 ===
Server answer:[0031] Dongle identification data damaged.
Old 01-28-2021, 02:45   #293 (permalink)
Member: 148515
Searching...
Reading...
Hello,
Please make step-by-step NOW:
- reboot PC
- update dongle with Infinity DongleManager.exe
- delete fault.bin file (if you have it in CM2 folder)
Before run Infinity CM2MT2 always close boot-helper installation package !
Old 01-28-2021, 02:48   #294 (permalink)
Member: 148515
new version not!
Make a note that Alcor reader works well !
Old 01-28-2021, 06:15   #295 (permalink)
Member: 2828679
=== DongleManager [Infinity] v1.81 [1/27/2021 19:30:08] ===
Box/Dongle type selected: Infinity-Box/Dongle [CM2]
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 000031A017B14082
Reading...
Serial No (S/N): 5BB931A0
=== Process started: 1/27/2021 19:30:09 ===
Old 01-28-2021, 07:02   #296 (permalink)
Member: 2566955
Sonork: 1673467
=== DongleManager [Infinity] v1.81 [1/28/2021 10:53:44] ===
Searching...
HWID: 0000179A21344082
Reading...
Serial No (S/N): 1579179A
=== Process started: 1/28/2021 10:53:45 ===
Write to Smart-Card/Dongle/Box update fixes and solutions - GSM-Forum
Old 01-28-2021, 07:04   #297 (permalink)
Member: 1970395
=== DongleManager [Infinity] v1.81 [28/1/2021 12:18:07] ===
HWID: 00007E8B12534082
Reading...
Serial No (S/N): C1707E8B
Firmware version: 0136.02
=== Process started: 28/1/2021 12:18:08 ===
Server answer:[0007] No updates found for your Smart-Card.
Smart-Card has latest firmware version or probably support period is expired.
How to check - https://www.infinity-box.com/doc/?r=17
If it's expired contact to your seller and renew support - https://www.infinity-box.com/buy/
Old 01-28-2021, 09:08   #298 (permalink)
Member: 2750957
Thanks Meter: 2
=== DongleManager [Infinity] v1.81 [28/1/2021 15:07:42] ===
HWID: 0000F05317004082
Reading...
Serial No (S/N): 6355F053
=== Process started: 28/1/2021 15:07:43 ===
Write to https://www.infinity-box.com/support/?r=2
Old 01-28-2021, 09:55   #299 (permalink)
Member: 2566222
Thanks Meter: 12
=== DongleManager [Infinity] v1.81 [28-01-2021 14:25:00] ===
Searching...
HWID: 0000137521344082
Reading...
Serial No (S/N): 12971375
=== Process started: 28-01-2021 14:25:01 ===
Old 01-28-2021, 10:23   #300 (permalink)
Member: 148515
Searching...
Reading...
Hello,
1. reboot PC
2. update dongle with Infinity DongleManager.exe
2. delete fault.bin file (if you have it in CM2 folder)
Close boot-helper installation package before run Infinity CM2MT2 !
Page generated in 0.24055 seconds with 10 queries
