02-01-2021, 11:14 | #361 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: 1. Delete fault.bin file (if you have it in CM2 folder) 2. Install latest Infinity software updates 3. Run DongleManager 4. Update Dongle firmware Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
02-01-2021, 15:09 | #362 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | Quote:
I have a lot of appreciation for infinity and its support. Thank you very much in advance. | |
02-01-2021, 15:58 | #363 (permalink) | |
If you still have a problem please follow the next steps - https://www.infinity-box.com/support/?r=100127 Write here your results step-by-step after you do it as per instruction Waiting for your STEP-BY-STEP report so now make => 1. Disable AVAST What is the result after this step ? | |
02-01-2021, 17:00 | #364 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1468634 Status: Offline Thanks Meter: 15 | after activating infibity dongle, echo updat my error came to now = DongleManager [Infinity] v1.81 [02/01/2021 16:50:30] === Searching ... Card-Reader: Generic CCID Smart Card Reader 0 HWID: 0007848608771292 Box / Dongle is not found not my function please help thanks |
02-01-2021, 17:06 | #365 (permalink) | |
Update it once again now. Result ? | |
02-02-2021, 07:40 | #366 (permalink) |
Junior Member Join Date: Feb 2009 Location: Philippines
Member: 979806 Status: Offline Thanks Meter: 0 | Serial No (S/N): BB6465A9 Firmware version: 0147.02 === Process started: 2/2/2021 14:39:21 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
02-02-2021, 11:16 | #367 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
2. Read Dongle S/N https://www.infinity-box.com/support/?s=7 3. Send file fault.bin and Dongle S/N text to support https://www.infinity-box.com/contact/ | |
02-02-2021, 18:53 | #368 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 996278 Status: Offline Sonork: 192.168.1.1 Thanks Meter: 40 | === DongleManager [Infinity] v1.80 [2/2/2021 19:47:08] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 3 HWID: 0108A97824881292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D0E7A978 Firmware version: 0147.02 === Process started: 2/2/2021 19:47:10 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
02-02-2021, 19:13 | #369 (permalink) | |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software ! 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe | |
02-05-2021, 13:42 | #371 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, - Run DongleManager.exe - https://www.infinity-box.com/support/?r=5 - Make "Read Serial Number (S/N)" DO NOT send screenshot/video but copy/paste text from software window ! |
02-05-2021, 15:43 | #372 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Suri (W.B) Age: 35
Member: 1251764 Status: Offline Thanks Meter: 95 | temporary suspended === DongleManager [Infinity] v1.81 [05-02-2021 20:03:07] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000F76B00001942 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 7088F76B Firmware version: 0116.02 === Process started: 05-02-2021 20:03:11 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0006] Your account is temporary suspended. See more in log file Write to https://www.infinity-box.com/support/?r=2 |
02-05-2021, 17:21 | #373 (permalink) | |
