Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 55,617 | Smart-Card/Dongle/Box update fixes and solutions In case of problem with your Dongle Smart-Card please copy/paste here text given by Infinity DongleManager software. Please copy/paste ONLY TEXT but not pictures and/or video Please DO NOT update your Smart-Card many times to avoid Smart-Card damage ! - If you have Card-Reader Type FT SCR2000 you should use special Card-Reader Drivers - CardReader_Fetian_FT2K.7z Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 - The next card-readers are very bad and should be replaced with another card-reader to avoid Smart-Card damage: DITS CCID Smart Card Reader DITS Ezy Smart Card reader USB Fenix Card reader - For today best results gives Alcor Smart-Card Readers. Previous threads are HERE and HERE and HERE and HERE ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() | #2 (permalink) |
Junior Member Join Date: Jun 2015 Location: INDIA
Member: 2411177 Status: Offline Thanks Meter: 0 | ![]() tool closed automatically when flashing gione p3 phone and after then cm2mt2 tool not opening fault bin is showing in install directory dongle manager is showing dongle misconfiguration plz solve it ASAP fault bin file attached dongle manager logs - === DongleManager [Infinity] v1.81 [1/7/2021 14:10:45] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: FT SCR2000 0 HWID: 000034E517B14082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 59BB34E5 Firmware version: 0146.02 === Process started: 1/7/2021 14:10:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Last edited by raj sonu; 01-07-2021 at 09:53. Reason: added dongle manager logs |
![]() | #3 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 55,617 | Quote:
After that update dongle firmware After that delete fault.bin In future use free unknown frp tools very carefully ! | |
![]() | #4 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 692 | === DongleManager [Infinity] v1.80 [07-Jan-21 16:18:12] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000CFC61A224082 Box/Dongle found: [BEST] Reading... Serial No (S/N): 841DCFC6 Firmware version: 0122.02 === Process started: 07-Jan-21 16:18:13 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
![]() | #5 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2003 Location: ALGERIA ,DZ
Member: 37521 Status: Offline Thanks Meter: 46 | === DongleManager [Infinity] v1.80 [1/7/2021 16:05:54] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0000108911384082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): A49F1089 Firmware version: 0146.02 === Process started: 1/7/2021 16:05:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 what to do please help |
![]() | #6 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: 1. Delete fault.bin file from software folder (if you have it there) 2. Install latest Infinity software updates 3. Run DongleManager 4. Update Dongle firmware Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
![]() | #7 (permalink) | |
After that update dongle firmware After that delete fault.bin | |
![]() | #8 (permalink) |
Junior Member Join Date: Nov 2017 Location: Uzbekistan, Bukhara
Member: 2775634 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.81 [09.01.2021 12:50:55] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 00001C5221F34082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 2FB41C52 Firmware version: 0146.02 === Process started: 09.01.2021 12:50:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
![]() | #9 (permalink) | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
![]() | #10 (permalink) |
Junior Member Join Date: Jan 2021 Location: by
Member: 2977008 Status: Offline Thanks Meter: 0 | Code: === DongleManager [Infinity] v1.81 [10.01.2021 22:03:06] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00006A0D1FDB4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): F1E36A0D Firmware version: 0146.02 Box/Dongle misconfiguration Diagnostic code: 5A what seems to be a problem here? |
![]() | #11 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 34,838 | Quote:
![]() | #13 (permalink) |
Major Poster ![]() ![]() Join Date: Jun 2017
Member: 2729037 Status: Offline Thanks Meter: 3 | Searching... Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 00012F341F444082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): E9A32F34 Firmware version: 0146.02 === Process started: 1/12/2021 10:22:21 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
