04-23-2021, 10:06 | #61 (permalink) |
Freak Poster Join Date: Feb 2010 Location: philippines Age: 41
Member: 1227914 Status: Offline Sonork: 100.1602872 Thanks Meter: 58 | Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00008AD617434082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 62628AD6 Firmware version: 0147.02 === Process started: 4/23/2021 16:34:59 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 please help me team |
04-23-2021, 13:22 | #62 (permalink) | |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe | |
04-23-2021, 15:22 | #63 (permalink) | |
Member: 1227914 Status: Offline Sonork: 100.1602872 Thanks Meter: 58 | Quote:
problem solved | |
04-24-2021, 11:09 | #64 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1527420 Status: Offline Thanks Meter: 16 | CM2 smart card misconfiguration. plz help when i run any cm2 setup show error :smart card misconfiguration Contact to support update info === DongleManager [Infinity] v1.81 [4/24/2021 14:46:04] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00079D7E20281292 Box/Dongle found: Infinity [BEST] Reading... Serial No (S/N): 8ECD9D7E Firmware version: 0122.02 === Process started: 4/24/2021 14:46:05 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
04-24-2021, 11:23 | #65 (permalink) | |
04-24-2021, 23:52 | #66 (permalink) |
Junior Member Join Date: Jul 2008 Location: egypt
Member: 823372 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.81 [4/25/2021 0:31:34] === Box/Dongle type selected: Infinity [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00078C8C18201292 Box/Dongle found: Infinity [BEST] Reading... Serial No (S/N): E3368C8C Firmware version: 0122.02 === Process started: 4/25/2021 0:31:35 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
04-25-2021, 16:16 | #67 (permalink) | |
04-25-2021, 21:03 | #68 (permalink) |
Member: 823372 Status: Offline Thanks Meter: 1 | why not work i follow your instructor after that i try to updat by dongle manger after try run cm2 exe not work then try to check dongle manger then give me this error === DongleManager [Infinity] v1.81 [4/25/2021 21:56:39] === Searching... Card-Reader: Generic USB Smart Card Reader 0 HWID: 00078C8C18201292 Box/Dongle found: Infinity [BEST] Reading... Serial No (S/N): E3368C8C Firmware version: 0122.02 === Process started: 4/25/2021 21:56:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 idont know where problem in my computer ... if need to check my computer by team view ok .or reinstall new windows 10 x64..... please help me my work is off without your support |
04-26-2021, 08:45 | #69 (permalink) |
Freak Poster Join Date: Sep 2008 Location: At the center of the Earth
Member: 851708 Status: Offline Sonork: 1000.2brian Thanks Meter: 15 | = DongleManager [Infinity] v1.81 [2021-04-26 10:35:17] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00001F351CC74082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): E7EB1F35 Firmware version: 0147.02 === Process started: 2021-04-26 10:35:18 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
04-26-2021, 10:29 | #70 (permalink) | |
but you killed it again because you again use usb sharing tool. Now make this: Upload file fault.bin to mega.nz and post link here. File is at /InfinityBox/CM2MT2/ or /InfinityBox/CM2SP2/ or /InfinityBox/BEST/ folder | |
04-26-2021, 10:30 | #71 (permalink) | |
04-26-2021, 14:42 | #72 (permalink) |
Major Poster Join Date: Sep 2007 Location: egypt
Member: 579107 Status: Offline Thanks Meter: 20 | please help me team and I dont have (fault.bin) file === DongleManager [Infinity] v1.81 [26/04/2021 15:36:55] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic USB Smart Card Reader 0 HWID: 00011E6D1CC74082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): E9181E6D Firmware version: 0148.02 === Process started: 26/04/2021 15:36:56 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
04-26-2021, 16:41 | #73 (permalink) | |
04-26-2021, 16:52 | #74 (permalink) | |
Member: 579107 Status: Offline Thanks Meter: 20 | Quote:
Thank you, sir done........ | |
04-26-2021, 19:22 | #75 (permalink) | |
Member: 823372 Status: Offline Thanks Meter: 1 | Quote:
i never used sharing tool https://mega.nz/file/ENNTjYra#lB3O5c...ORu1trXqzyVImQ | |
