04-09-2021, 09:56 | #31 (permalink) | |
Inform me after that, I will tell you the next step | |
04-09-2021, 10:18 | #32 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
please use google translate and read now: you must uninstall ELTIMA/FLEXIHUB from your PC. Do it now and tell us when done Ok? | |
04-10-2021, 06:49 | #33 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2793330 Status: Offline Sonork: family Thanks Meter: 0 | === DongleManager [Infinity] v1.80 [4/10/2021 10:47:00] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: GsmEasy S-Reader 0 HWID: 00001CF121F34082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 32EA1CF1 Firmware version: 0147.02 === Process started: 4/10/2021 10:47:02 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
04-10-2021, 08:29 | #34 (permalink) |
Member: 2793330 Status: Offline Sonork: family Thanks Meter: 0 | Defender off ha share softwere install nahi hy phir b card update nahi ho raha sir..plz === DongleManager [Infinity] v1.80 [4/10/2021 12:06:39] === Searching... Card-Reader: GsmEasy S-Reader 0 HWID: 00001CF121F34082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 32EA1CF1 Firmware version: 0147.02 === Process started: 4/10/2021 12:06:41 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
04-10-2021, 10:04 | #35 (permalink) | |
Uninstalled or not yet? | |
04-10-2021, 22:53 | #36 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2519711 Status: Offline Sonork: +213777494778 Thanks Meter: 0 | Hello infinity team my name is yahya I buy a cm2 dongle 4 days know I registered it and start working with it And after installing cm2mt2 software and he didn't work I try to update firmware with infinity dongle manager 1.80 so he gives me that read === DongleManager [Infinity] v1.80 [10-04-2021 16:58:05] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000CD1221344082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 3C54CD12 Firmware version: 0147.02 === Process started: 10-04-2021 16:58:06 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to *********infinity-support And when I read the serial number I get this read === DongleManager [Infinity] v1.80 [10-04-2021 17:35:21] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000CD1221344082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 3C54CD12 Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0032 v.0147 => Activations: - 00: Infinity-Box/Dongle v0147 => Options: - Infinity-Box/Dongle With the diagnostic code :66 So I research the internet and try to fix it by myself by rieninstall everything and start over but it didn't work then I tried in another PC then in another one but nothing happened same problem so I go to one of my friend who have the same dongle that's work on his PC but my dongle gave us the same message. that's all please help me. |
04-11-2021, 09:53 | #37 (permalink) | |
Today you killed it with usb sharing again. 1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. confirm here that two steps done. after that you will get the next instruction | |
04-11-2021, 12:39 | #41 (permalink) | |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe | |
04-15-2021, 20:57 | #45 (permalink) |
Junior Member Join Date: Sep 2009 Location: Nakło
Member: 1120364 Status: Offline Thanks Meter: 0 | i update because buy activation mc2 and i have error "We have successfully activated Infinity Chinese Miracle-2 for BEST Dongle SN: A87E9574" === DongleManager [Infinity] v1.81 [15.04.2021 19:57:42] === Box/Dongle type selected: Infinity [BEST] Card-Reader: FT SCR2000 0 HWID: 0100957418201292 === Process started: 15.04.2021 19:57:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
