Old 06-23-2021, 00:24   #31 (permalink)
Member: 1043909
Thanks Meter: 58,016
Originally Posted by emad_emad59 View Post
=== DongleManager [Infinity] v1.81 [6/21/2021 19:18:49] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 00004E2F1BE14082
Box/Dongle found: Infinity-Box/Dongle [CM2]
Reading...
Serial No (S/N): EE7A4E2F
Firmware version: 0147.02
=== Process started: 6/21/2021 19:18:50 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Write to https://www.infinity-box.com/support/?r=2
Hello,
1. Read NOTE - https://infinity-box.com/support/?s=2
2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software.
3. Update dongle with Infinity DongleManager.exe
4. Delete fault.bin file (if you have it in CM2 folder)
5. Run Infinity exe
Old 06-24-2021, 18:33   #32 (permalink)
Member: 2493753
Hello,
Two days ago, the problem appeared that it was not possible to open any of the Infinity programs "smart-card misconfiguration contact to support"
=== DongleManager [Infinity] v1.81 [24/06/2021 18:16:15] ===
Box/Dongle type selected: Infinity-Box/Dongle [CM2]
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 000016271CC74082
Reading...
Serial No (S/N): E35F1627
Firmware version: 0149.02
=== Process started: 24/06/2021 18:16:16 ===
How can you solve this problem please
thank you
Old 06-24-2021, 21:04   #33 (permalink)
Member: 1043909
Originally Posted by india90 View Post
Hello,
Reading...
thank you
Don't make repeated posts, check your other thread
Old 07-05-2021, 15:23   #34 (permalink)
Member: 1550235
=== DongleManager [Infinity] v1.81 [05/07/2021 13:39:44] ===
Searching...
HWID: 0104A27420881292
Box/Dongle found: Infinity [BEST]
Serial No (S/N): 8CBEA274
Firmware version: 0122.02
Box/Dongle misconfiguration
Diagnostic code: 66
=> Online Service:
- Username: 038CBEA274
- Password: ....
Diagnostic key: 7F666B0C5E2352B9
Old 07-05-2021, 23:41   #35 (permalink)
Member: 1043909
Searching...
Diagnostic code: 66
=> Online Service:
- Password: ....
Hello,
5. Run Infinity exe
Old 07-08-2021, 20:44   #36 (permalink)
Member: 1189971
Thanks Meter: 11
i need some help ??
=== DongleManager [Infinity] v1.85 [08/07/2021 10:38:28 ] ===
HWID: 0001252121344082
Reading...
Serial No (S/N): F7DF2521
=== Started: 08/07/2021 10:38:30 ===
Connecting to server...
Connection successfully established
Server answer: [0031] Dongle identification data damaged.
The Following User Says Thank You to ayham-love For This Useful Post:
Old 07-08-2021, 23:15   #37 (permalink)
Member: 1043909
It is 3rd time you have the same issue with usb sharing.
Click here https://infinity-box.com/support/?r=100155
See screenshot with info
Follow the instruction
Old 07-09-2021, 03:31   #38 (permalink)
Member: 1258908
Thanks Meter: 2
=== DongleManager [Infinity] v1.85 [2021/7/9 10:30:19] ===
Searching...
HWID: 0001082713114082
Reading...
Serial No (S/N): 98F80827
Firmware version: 0148.02
=== Started: 2021/7/9 10:30:20 ===
fault.bin https://mega.nz/file/jk0BCYbb#v-YTSF...qKsKcsDhbqG0KY
Old 07-09-2021, 08:04   #39 (permalink)
Member: 1043909
Searching...
Reading...
5. Run Infinity exe
Old 07-10-2021, 10:40   #40 (permalink)
Member: 1222925
Thanks Meter: 13
Exclamation Problem infinity box
I try to update and:
=== DongleManager [Infinity] v1.85 [7/10/2021 12:26:58 PM] ===
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 00015221FF021982
=== Started: 7/10/2021 12:26:59 PM ===
Server answer: [0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
then i try to to report and fix and
Username: 0001545221
==> Scan D:\decodare\InfinityBox for report.log
==> Scan c:\InfinityBox for report.log
==> Scan c:\Program Files for report.log
==> Scan d:\Program Files for report.log
==> Scan c:\Program Files (x86) for report.log
Found files: 0
==> Scan D:\decodare\InfinityBox for *.box
==> Scan c:\InfinityBox for *.box
==> Scan c:\Program Files for *.box
==> Scan d:\Program Files for *.box
==> Scan c:\Program Files (x86) for *.box
Found files: 0
==> Scan D:\decodare\InfinityBox for fault.bin
==> Scan c:\InfinityBox for fault.bin
==> Scan c:\Program Files for fault.bin
==> Scan d:\Program Files for fault.bin
==> Scan c:\Program Files (x86) for fault.bin
Found files: 3
Upload: D:\decodare\InfinityBox\BEST\fault.bin
Could not load SSL library.
Upload: D:\decodare\InfinityBox\CM2MTK\fault.bin
Upload: D:\decodare\InfinityBox\CM2SPD\fault.bin
PLEASE HELP ME!
Old 07-10-2021, 22:28   #41 (permalink)
Member: 1043909
Found files: 0
Found files: 0
Found files: 3
PLEASE HELP ME!
Delete DongleManager
Download it again here https://infinity-box.com/support/?r=19
Run it and make "Fix" now
Old 07-12-2021, 07:21   #42 (permalink)
Member: 2775634
Thanks Meter: 2
=== DongleManager [Infinity] v1.81 [12.07.2021 11:19:34] ===
HWID: 00001C5221F34082
Reading...
Serial No (S/N): 2FB41C52
=== Process started: 12.07.2021 11:19:35 ===
Old 07-12-2021, 17:48   #43 (permalink)
Member: 2768253
=== DongleManager [Infinity] v1.85 [7/12/2021 18:47:03] ===
Searching...
HWID: 00012CE31F444082
Reading...
Serial No (S/N): E96F2CE3
=== Started: 7/12/2021 18:47:04 ===
Old 07-13-2021, 00:13   #44 (permalink)
Member: 1043909
Reading...
Hello,
To avoid software conflicts in future please do not use `Hexframe` at the same time with Infinity software.
What to do now:
1. Install latest Infinity software updates
2. Run DongleManager
3. Update Dongle firmware
4. Delete fault.bin file if you have it in [CM2] or [BEST] folder
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 07-13-2021, 00:14   #45 (permalink)
Member: 1043909
Searching...
Reading...
Hi,
It's 3rd time you have the same problem with your PC. It liiks like you still did nit uninstalled usb sharing tools.
Click here and follow the instruction https://infinity-box.com/support/?r=100155 to get it fixed
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.24018 seconds with 7 queries
