Old 07-17-2021, 12:44   #61 (permalink)
Member: 2983727
Thanks Meter: 16
== DongleManager [Infinity] v1.81 [7/17/2021 16:38:31] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 00002AE621F34082
Box/Dongle found: Infinity-Box/Dongle [CM2]
Reading...
Serial No (S/N): 413E2AE6
Firmware version: 0149.02
=== Process started: 7/17/2021 16:38:32 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Write to https://www.infinity-box.com/support/?r=2
Old 07-17-2021, 12:55   #62 (permalink)
Member: 1043909
Thanks Meter: 60,926
Searching...
Reading...
Hello,
1. Read NOTE - https://infinity-box.com/support/?s=2
2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software.
3. Update dongle with Infinity DongleManager.exe
4. Delete fault.bin file (if you have it in CM2 folder)
5. Run Infinity exe
Old 07-17-2021, 13:14   #63 (permalink)
Member: 2983727
Thanks Meter: 16
Searching...
Reading...
solved the issue it was virtual serial com port driver . please whitelist this program it's not for sharing it's for stable driver. some times mtk port connect n disconnects immediately or auto disconnect during flashing so i installed this program don't know what it does but makes a stable connection. i have uninstalled this n updated card now everything ok. but please check this it's not sharing https://www.virtual-serial-port.org/
Old 07-17-2021, 15:32   #64 (permalink)
Member: 1043909
In future use this method https://infinity-box.com/support/?r=100155 and we will be able to check what was the real reason of the problem
Old 07-20-2021, 09:47   #65 (permalink)
Member: 1608526
Sonork: 100.1611913
Thanks Meter: 60
Thumbs up i just renew support
=== DongleManager [Infinity] v1.85 [7/20/2021 1:43:29 AM] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0001646DFF021982
Reading...
Serial No (S/N): 0676646D
Firmware version: 0136.02
=== Started: 7/20/2021 1:43:34 AM ===
Connecting to server...
Connection successfully established
Server answer: [0006] Your account is temporary suspended.
See more in log file
Old 07-20-2021, 13:38   #66 (permalink)
Member: 148515
Thanks Meter: 19,534
Searching...
Reading...
This card is from year 2007 (14 years old) so it may be hardware fault.
First time fault was detected in year 2020 and I think you know that.
If you have another card-reader I suggest you insert card into another reader.
Try to update dongle firmware now, let's see result.
Old 07-23-2021, 14:55   #67 (permalink)
Member: 1125925
Thanks Meter: 8
hi infinity team
i have this problem ;;; dongle misconfigiration
=== DongleManager [Infinity] v1.87 [23/07/2021 14:53:40] ===
Box/Dongle type selected: Infinity [BEST]
HWID: 0101875D10321292
Box/Dongle found: Infinity [BEST]
Reading...
Serial No (S/N): 9504875D
Firmware version: 0122.02
=== Started: 23/07/2021 14:53:41 ===
Server answer: [0031] Dongle identification data damaged.
Old 07-23-2021, 16:00   #68 (permalink)
Member: 148515
Originally Posted by the desaster View Post
hi infinity team
Answered in your other thread
Old 07-23-2021, 18:36   #69 (permalink)
Registered User
Member: 1113983
I have this problem dongle misconfigiration
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0106736418571292
Serial No (S/N): 78D17364
Box/Dongle misconfiguration
Diagnostic code: 5A
"UK Edition" status: Off
Last launched Application: 0030 v.0158
=> Activations:
- 00: Infinity-Box/Dongle [CM2] v0143
- 03: Infinity [BEST] v0122
=> Options:
- Infinity [BEST]
- Infinity [BEST2]
Old 07-23-2021, 18:53   #70 (permalink)
Registered User
Member: 1113983
Diagnostic code: 5A
=> Activations:
=> Options:
- Infinity [BEST]
- Infinity [BEST2]
Old 07-23-2021, 19:38   #71 (permalink)
Member: 148515
Diagnostic code: 5A
=> Activations:
=> Options:
- Infinity [BEST]
- Infinity [BEST2]
Hello,
To avoid software conflicts in future please do not use `Hexframe` at the same time with Infinity software.
What to do now:
1. Install latest Infinity software updates
2. Run DongleManager
3. Update Dongle firmware
4. Delete fault.bin file if you have it in [CM2] or [BEST] folder
Old 07-25-2021, 18:28   #72 (permalink)
ChuyenMobileGsm's Avatar
Member: 2984558
Thanks Meter: 634
=== DongleManager [Infinity] v1.81 [7/26/2021 0:27:40] ===
Searching...
HWID: 000030A017B14082
Reading...
Serial No (S/N): 5DA130A0
=== Process started: 7/26/2021 0:27:42 ===
Old 07-25-2021, 21:56   #73 (permalink)
Member: 148515
Searching...
Reading...
Hi,
What kind of crack or debug tools do you use at your PC?
You can make this to get it fixed https://infinity-box.com/support/?r=100155
Waiting for your info or result with auto-fix
Old 07-27-2021, 13:41   #74 (permalink)
Member: 2931678
Thanks Meter: 28
hello sir help me to fix this error
also there is no logs in folder
Username: 00DDC6BD1B
==> Scan c:\users\muhammad\downloads\compressed\donglemanag er_2 for report.log
==> Scan c:\InfinityBox for report.log
==> Scan c:\Program Files for report.log
==> Scan c:\Program Files (x86) for report.log
Found files: 0
==> Scan c:\users\muhammad\downloads\compressed\donglemanag er_2 for *.ibin.log
==> Scan c:\InfinityBox for *.ibin.log
==> Scan c:\Program Files for *.ibin.log
==> Scan c:\Program Files (x86) for *.ibin.log
Found files: 0
==> Scan c:\users\muhammad\downloads\compressed\donglemanag er_2 for fault.bin
==> Scan c:\InfinityBox for fault.bin
==> Scan c:\Program Files for fault.bin
==> Scan c:\Program Files (x86) for fault.bin
Found files: 0
plz infiniti team help me
Last edited by muhammadsaif; 07-27-2021 at 13:46. Reason: also there is nO FAULT.BIN file in folder
Old 07-28-2021, 08:27   #75 (permalink)
Member: 148515
Found files: 0
Found files: 0
Found files: 0
Hello,
Please in future DO NOT delete fault.bin file because this file helps to fix your PC. Now make this:
5. Run Infinity software
Page generated in 0.29971 seconds with 10 queries
