Old 07-31-2021, 11:49   #1 (permalink)
Member: 148515
Thanks Meter: 19,534
Smart-Card/Dongle/Box update fixes and solutions
1. Download latest Infinity DongleManager - version 1.87 or higher is required
2. Click to Report & Fix Issue
3. Wait some time and you will get an answer
If you still have a problem make this:
- copy/paste ONLY TEXT
- no pictures and video
- DO NOT update your Smart-Card many times - you can kill Smart-Card
The Following 11 Users Say Thank You to InfinityHelp For This Useful Post:
Old 08-01-2021, 12:16   #2 (permalink)
Member: 1793074
Sonork: kashif1986k
Thanks Meter: 11
=== DongleManager [Infinity] v1.87 [8/1/2021 1:11:14 PM] ===
Box/Dongle type selected: Infinity-Box/Dongle [CM2]
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 00008A19237A4082
Box/Dongle found: Infinity-Box/Dongle [CM2]
Reading...
Serial No (S/N): 49D88A19
Firmware version: 0149.02
=== Started: 8/1/2021 1:11:15 PM ===
Connecting to server...
Connection successfully established
Checking DongleManager version...
DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer: [0031] Dongle identification data damaged.
Write to https://www.infinity-box.com/support/?r=2
Do you want to report an issue to Support?
Please help me because Its not sending reports also
The Following 4 Users Say Thank You to kashif1984k For This Useful Post:
Old 08-01-2021, 12:42   #3 (permalink)
Member: 148515
Reading...
Please use Report & Fix button now.
Result?
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post:
Old 08-02-2021, 08:22   #4 (permalink)
Member: 148515
Reading...
Sir, you tried to update this dongle firmware about 50 times during last 2 days.
This way is just waste of time in your situation.
To get your dongle fixed you should send report to support server first and after that you will get an instruction from supporters.
And only after that supporters will tell you when you can update your dongle firmware.
So send report first.
Waiting.
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 08-02-2021, 13:58   #5 (permalink)
Member: 2931678
Thanks Meter: 28
hello infinity team i have one more cm2 and it also got the same problum but i didnt use any flexihub or any more same like softwers plz help me
Reading...
Serial No (S/N): 1758B4E1
Firmware version: 0150.02
=== Process started: 2021/07/30 09:37:48 ===
Server connection successfully established
Your DongleManager is up-to-date
Server answer:[0031] Dongle identification data damaged
[8:39 am, 30/07/2021] Shakeel bhai Boksburg: Box/Dongle type selected: Infinity-Box/Dongle [CM2]
Box/Dongle misconfiguration
Diagnostic code: 66
Username: 001758B4E1
==> Scan c:\users\malik\downloads\compressed\donglemanager for report.log
==> Scan c:\InfinityBox for report.log
==> Scan c:\Program Files for report.log
==> Scan c:\Program Files (x86) for report.log
Found files: 0
==> Scan c:\users\malik\downloads\compressed\donglemanager for *.ibin.log
==> Scan c:\InfinityBox for *.ibin.log
==> Scan c:\Program Files for *.ibin.log
==> Scan c:\Program Files (x86) for *.ibin.log
Found files: 0
==> Scan c:\users\malik\downloads\compressed\donglemanager for fault.bin
==> Scan c:\InfinityBox for fault.bin
==> Scan c:\Program Files for fault.bin
==> Scan c:\Program Files (x86) for fault.bin
Found files: 0
No reports found
[8:39 am, 30/07/2021] Shakeel bhai Boksburg: === DongleManager [Infinity] v1.87 [2021/07/30 09:40:03 AM] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0000B4E1217A4082
Diagnostic code: 66
"UK Edition" status: Off
Last launched Application: 0030 v.0150
=> Activations:
- 00: Infinity-Box/Dongle [CM2] v0150
=> Options:
- Infinity-Box/Dongle [CM2]
1- Flexihub never been installed|used in this system nor eltima drivers...
2-NO usb sharing tools have been used...
3- Fresh Windows installed...
4- eVEN I HAVE CHECKED THERE IS NO fAULT.BIN file inside infinity folder...
prolem still exist even i update dongle firmware
REGARDS
The Following 3 Users Say Thank You to muhammadsaif For This Useful Post:
Old 08-02-2021, 15:32   #6 (permalink)
Member: 148515
I have opened your conversation with other supporter, you told the same first but after that you told "yesterday flexihub was uninstalled".
You told the same earlier but once other supporter provide you proof you told it was installed
error 66 means it was usb sharing or similar tool. I am confused now.
Hm.. Have you re-installed fresh windows to all your PC already?
Please check all your PC once again and send me fault.bin file.
If you can not find file plz explain what usb sharing tool you have used. I need this info to find a solution for your problem.
REGARDS
Of coures it exist. I told you - DO NOT update dongle firmware without my apporoval, tries are useless, first you should tell me info and then we will think together how to fix your problem
I am waitng for your info!
Old 08-04-2021, 13:20   #7 (permalink)
umairabubakkar's Avatar
Member: 2492126
Sonork: 100.1676056
Thanks Meter: 21
Data Damaged
== DongleManager [Infinity] v1.80 [8/2/2021 20:15:24] ===
HWID: 000010340EFE4082
Reading...
Serial No (S/N): B0061034
Firmware version: 0148.02
=== Process started: 8/2/2021 20:15:25 ===
Server answer:[0031] Dongle identification data damaged.
The Following 3 Users Say Thank You to umairabubakkar For This Useful Post:
Old 08-04-2021, 14:36   #8 (permalink)
Member: 2931678
Thanks Meter: 28
i have never been used flexihub to share cm2 or any other softwere like flexihub yes i agree with u because i update cm2 without ur permition but my one cm2 o already ok but the 2nd one is not ok after updating
but realy sory for that i update cm2 witout ur permition
now i m using new window i uninstaled old window and reinstalled new one but my issu is same and i never get fault.bin file.
So now what must i do i just request infinity team to help me
Regards
The Following 4 Users Say Thank You to muhammadsaif For This Useful Post:
Old 08-05-2021, 10:28   #9 (permalink)
Safyan sufi's Avatar
Member: 2221849
Sonork: offline
Thanks Meter: 279
@Infinity box please help.
Box/Dongle type selected: Infinity [BEST]
Diagnostic code: 66
Username: 03A80D6572
==> Scan C:\Users\Admin\Downloads\DongleManager for report.log
Found files: 0
==> Scan C:\Users\Admin\Downloads\DongleManager for *.ibin.log
Found files: 0
==> Scan C:\Users\Admin\Downloads\DongleManager for fault.bin
Found files: 0
No reports found
The Following User Says Thank You to Safyan sufi For This Useful Post:
Old 08-06-2021, 08:33   #10 (permalink)
Member: 1043909
Thanks Meter: 60,926
Reading...
1. Read NOTE - https://infinity-box.com/support/?s=2
2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software.
3. Update dongle with Infinity DongleManager.exe
4. Run Infinity software
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 08-06-2021, 08:34   #11 (permalink)
Member: 1043909
Regards
Wait friend, I need some time to check previous conversation to find a way.
Old 08-06-2021, 08:38   #12 (permalink)
Member: 1043909
Diagnostic code: 66
Found files: 0
Found files: 0
Found files: 0
No reports found
Please before you will start your dongle fix process contact to person who suggested you to delete fault.bin file and told him that his IQ is zero and that his advice was plain stupid. In future please do not follow advices of stupid people with zero IQ but please contact to support team directly for best results.
What to do now:
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 08-06-2021, 08:44   #13 (permalink)
Member: 1043909
not true
I can not understand why do you continue to say that even after you told earlier "it was uninstalled". Anyway it's up to you.
Regards
- Read NOTE - https://infinity-box.com/support/?s=2
- Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software
Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle!
- Update dongle with Infinity DongleManager.exe
Old 08-15-2021, 11:06   #14 (permalink)
Member: 1793074
Sonork: kashif1986k
Thanks Meter: 11
=== DongleManager [Infinity] v1.81 [8/15/2021 12:04:48] ===
Searching...
Reading...
=== Process started: 8/15/2021 12:04:50 ===
Hi Sir,I have this problem please have a look and let me know how to solve this issue
Thanks in advance
The Following 2 Users Say Thank You to kashif1984k For This Useful Post:
Old 08-15-2021, 11:35   #15 (permalink)
Member: 1793074
Sonork: kashif1986k
Thanks Meter: 11
Hi sir,i HAVE 2 CM2 DONGLE 1 IS WORKINGF FINE AND OTHER ONE IS SHOWING THIS ERROR iIN THE SAME PC (Smart -Card misconfiguration! Contact to Support!) and when i update with dongle manager 1.81 it shows (Server answer:[0031] Dongle identification data damaged
=== DongleManager [Infinity] v1.81 [8/15/2021 12:04:48] === Searching... Card-Reader: Generic EMV Smartcard Reader 0
Reading...
I have these problems please have a look and let me know how to solve this issue
The Following 3 Users Say Thank You to kashif1984k For This Useful Post:
Page generated in 0.29435 seconds with 10 queries
