LinkBack Thread Tools
Old 01-18-2022, 17:58
Member: 1956406
Sonork: 1985
=== DongleManager [Infinity] v1.89 [1/18/2022 8:56:10 AM] ===
Box/Dongle type selected: Infinity-Box/Dongle [CM2]
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0001241A21344082
Box/Dongle found: Infinity-Box/Dongle [CM2]
Reading...
Serial No (S/N): F6BA241A
Firmware version: 0145.02
=== Started: 1/18/2022 8:56:12 AM ===
Connecting to server...
Connection successfully established
Checking client version...
Client is up-to-date
Checking Box/Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer: [0007] Not translated. Update this software to latest version!
Old 01-18-2022, 19:17
Member: 148515
Thanks Meter: 19,544
Reading...
Hello,
Your dongle support period is expired 2020-Aug-16
You can use previous software versions unlimited.
If you want to use latest software updates you should renew support.
Contact to any seller https://infinity-box.com/buy/
Send your dongle S/N to seller
Order [CM2] support renew for 1 or 2 years
How to check support period - https://infinity-box.com/doc/?r=17
Old 01-20-2022, 12:50
Member: 2891296
Sonork: 100-1616786
Thanks Meter: 157
Username: 0011C80290
==> Scan F:\Devices_Software\CM2 infinity_Data\DongleManager\ for report.log
==> Scan c:\InfinityBox\ for report.log
==> Scan c:\Program Files\ for report.log
==> Scan c:\Program Files (x86)\ for report.log
Found files: 0
==> Scan F:\Devices_Software\CM2 infinity_Data\DongleManager\ for *.ibin.log
==> Scan c:\InfinityBox\ for *.ibin.log
==> Scan c:\Program Files\ for *.ibin.log
==> Scan c:\Program Files (x86)\ for *.ibin.log
Found files: 0
==> Scan F:\Devices_Software\CM2 infinity_Data\DongleManager\ for fault.bin
==> Scan c:\InfinityBox\ for fault.bin
==> Scan c:\Program Files\ for fault.bin
==> Scan c:\Program Files (x86)\ for fault.bin
Found files: 0
No reports found
Old 01-20-2022, 13:11
Member: 1043909
Thanks Meter: 61,455
Found files: 0
Found files: 0
Found files: 0
No reports found
Hello,
1. Read this https://infinity-box.com/legal/eula/
2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software
3. Reboot PC
Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle!
4. Update dongle firmware with Infinity DongleManager
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 01-21-2022, 21:55
Member: 2959226
=== DongleManager [Infinity] v1.89 [21/01/2022 20:27:34] ===
HWID: 0000BAA821F34082
Reading...
Serial No (S/N): 2F23BAA8
Firmware version: 0150.02
=== Started: 21/01/2022 20:27:35 ===
Checking DongleManager version...
DongleManager is up-to-date
Checking Dongle Identification...
Server answer: [0031] Dongle identification data damaged.
Write to https://www.infinity-box.com/support/?r=2
Do you want to report an issue to Support?
Old 01-21-2022, 22:47
Member: 1043909
Reading...
Hello,
3. Reboot PC
Old 01-24-2022, 17:54
Member: 757272
Thanks Meter: 36
=== DongleManager [Infinity] v1.89 [1/24/2022 11:53:27 AM] ===
Box/Dongle type selected: Infinity [BEST]
Card-Reader: FT SCR2000 0
HWID: 0101699154884812
=== Started: 1/24/2022 11:53:27 AM ===
Server answer: [0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Old 01-24-2022, 19:18
Member: 2828575
Thanks Meter: 6
=== DongleManager [Infinity] v1.89 [1/24/2022 8:16:11 PM] ===
HWID: 0102A18320281292
Box/Dongle found: Infinity [BEST]
Reading...
Serial No (S/N): D632A183
Firmware version: 0122.02
=== Started: 1/24/2022 8:16:12 PM ===
Old 01-25-2022, 01:00
Member: 1043909
Hello,
This Smart-Card is not an Infinity Smart-Card
- Disconnect all other Boxes and Dongles from PC
- Connect ONLY one Infinity Box/Dongle to PC
Member: 1043909
Reading...
Hello,
3. Reboot PC
Old 02-10-2022, 20:45
ffhfox's Avatar
Member: 296215
Thanks Meter: 57
card error....
=== DongleManager [Infinity] v1.89 [2/10/2022 2:45:26 PM] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 00042832FF021982
Serial No (S/N): 14682832
Firmware version: 0112.02
"UK Edition" status: On
Last launched Application: 001F v.0304
Username: 0014682832
==> Scan c:\users\ffhfo\downloads\donglemanager\ for report.log
Found files: 0
==> Scan c:\users\ffhfo\downloads\donglemanager\ for *.ibin.log
Found files: 0
==> Scan c:\users\ffhfo\downloads\donglemanager\ for fault.bin
Found files: 0
No reports found
Old 02-10-2022, 20:54
Member: 148515
Searching...
Found files: 0
Found files: 0
Found files: 0
No reports found
Hi,
This card is damaged and can not be updated any more. You can use it but with very old CM software only.
THis card is in broken state sinse year 2010 or something like that
Old 02-11-2022, 07:13
xerraco's Avatar
Member: 890926
Thanks Meter: 2,088
Error login at IOS Support, 2 yrs new support activation, whats the problem?
Wrong username or password
=== DongleManager [Infinity] v1.89 [2/11/2022 1:31:06 PM] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 00001D0721F34082
Serial No (S/N): 33171D07
Firmware version: 0152.02
=> Online Service:
Br,
xerraco
Old 02-11-2022, 14:37
Member: 148515
Searching...
=> Online Service:
Br,
xerraco
This issue has no relation to support date or something like that.
You forgot your Infinity account password.
See info here https://infinity-box.com/service/
Reset password here - https://infinity-box.com/?r=17
Old 02-13-2022, 09:48
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,660
Exclamation
my client got dongle locked due to suspicious activities but already warning him about forbidden apps!
=== DongleManager [Infinity] v1.88 [13/02/2022 08:30:24] ===
Searching...
HWID: 000007E023604082
Reading...
Serial No (S/N): 4FD307E0
=== Started: 13/02/2022 08:30:26 ===
No
The Following User Says Thank You to yuranc8 For This Useful Post:
Page generated in 0.23327 seconds with 9 queries
