Old 07-05-2020, 19:08   #76 (permalink)
Member: 1618416
Thanks Meter: 27
smart card not detecting
hello sir need help very urgent my card not working anymore i don,t know what heppand card not detecting only unknown usb device i am getting plz help sir thanks in advance u can my id ditail on site
Token
- Type: Infinity-Box/Dongle
- Account Status: Active
- Hardware Status: Ok
Services
- Activation 1: (0) Infinity-Box/Dongle; S/N: 078A66E8; Firmware Version: 0136; Registered: 17-Jan-2007; Expired: 29-Dec-2017; Support: Expired
- Activation 2: (3) Infinity [BEST]; Firmware Version: 0122; Registered: information will be available in some time; Expired: N/A; Support: N/A
- Activation 3: (8) GB-Key; S/N: F000003C
- More Services may be active but not listed
Old 07-05-2020, 23:03   #77 (permalink)
Member: 130995
Thanks Meter: 35,227
Token
Services
This dongle is from year 2007, it's 13 - 14 years old !
Try to connect Dongle to another PC
Try to insert Smart-Card into another Card-Reader or Box
If problem still exist:
​- Remove Smart-Card from Card-Reader
- Clean Smart-Card contacts
- Try to use hot air gun and heat Smart-Card
- Insert Smart-Card back to Card-reader​
If problem still exist this means it's a hardware problem and you should buy new Dongle.
Old 07-06-2020, 21:55   #78 (permalink)
Member: 1892086
Sonork: 1671742
Thanks Meter: 282
hello, i updated my infinity dongle
=== DongleManager [Infinity] v1.80 [06-Jul-20 16:47:50] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 000030D70E1D4082
Box/Dongle found: Infinity-Box/Dongle
Serial No (S/N): B83C30D7
Firmware version: 0138.02
"UK Edition" status: Off
Last launched Application: 0030 v.0158
=> Activations:
- 00: Infinity-Box/Dongle v0138
- 03: [BEST] v0122
- 07: #7
- 0D: #13
- 0E: #14
=> Options:
- Infinity-Box/Dongle
- Infinity SM
- hua
- micro-box
but when i open cm2mt2 v2.12 i get dongle firmware version is outdated again
help please
Old 07-07-2020, 14:32   #79 (permalink)
Member: 1043909
Thanks Meter: 60,926
Searching...
=> Activations:
- 03: [BEST] v0122
- 07: #7
- 0D: #13
- 0E: #14
=> Options:
- Infinity SM
- hua
- micro-box
help please
Hello,
It looks like your dongle support period is expired.
How to check - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/
Old 07-08-2020, 22:41   #80 (permalink)
Crazy Poster
Member: 2253968
=== DongleManager [Infinity] v1.80 [7/8/2020 22:37:47] ===
Box/Dongle type selected: [BEST]
Card-Reader: FT SCR2000 0
HWID: 0102885803EF1292
=== Process started: 7/8/2020 22:37:47 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
Old 07-09-2020, 07:27   #81 (permalink)
Crazy Poster
Member: 2253968
Plss I need help. After I activated 2 years support for Chinese miracle 2. Then this happened when trying to upgrade smartcard..
Old 07-09-2020, 09:49   #82 (permalink)
Member: 148515
Thanks Meter: 19,534
Hello,
Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - https://www.infinity-box.com/support/?r=6
OR
Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
- run DongleManager
- update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
Old 07-09-2020, 10:59   #83 (permalink)
Member: 737774
Thanks Meter: 3
=== DongleManager [Infinity] v1.80 [09-Jul-20 10:58:45] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 00043886FF021982
Reading...
Serial No (S/N): 3FC03886
Firmware version: 0144.02
=== Process started: 09-Jul-20 10:58:49 ===
Server answer:[0031] Dongle identification data damaged.
HELP
PLEASE HELP
Old 07-09-2020, 14:19   #84 (permalink)
Crazy Poster
Member: 2253968
==== [7/9/2020 13:18:42] ====
Smart-Card update process may takes up to 4-5 minutes to complete.
During update process software may seem hanging but please DO NOT close or terminate forcely application.
It may cause harm to your Smart-Card. Just let the process to be finished.
- Connect Infinity Box/Dongle (Smart-Card) to PC
- Disconnect all other Boxes/Dongles (Smart-Card) from PC
- Update Smart-Card Reader drivers to latest version
- Disable Antivirus and Firewall
- DO NOT interrupt update process even if you think that software is freez !
=== DongleManager [Infinity] v1.80 [7/9/2020 13:18:46] ===
Searching...
Box/Dongle is not found
=== DongleManager [Infinity] v1.80 [7/9/2020 13:18:48] ===
Searching...
=== DongleManager [Infinity] v1.80 [7/9/2020 13:18:51] ===
Searching...
Select Token Type: instead of Autodetect
=== DongleManager [Infinity] v1.80 [7/9/2020 13:18:59] ===
=== Process started: 7/9/2020 13:19:00 ===
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Card returned error - 0000 at 290/9636
Error upgrading applets:
Disconnected
pls help me.. i need to use cm2mt2 latest version..plssss
Old 07-09-2020, 14:37   #85 (permalink)
Member: 148515
Searching...
Reading...
HELP
PLEASE HELP
Hello,
Attach fault.bin file from folder C:\InfinityBox\CM2MT2\ or C:\InfinityBox\CM2SP2\
Old 07-09-2020, 14:39   #86 (permalink)
Member: 148515
Searching...
Searching...
Searching...
Securing session...
Session secured ok
Upgrading dongle...
Disconnected
Install special drivers as per previous instruction.
Let me know after you install it, I will tel you what to do next
Old 07-09-2020, 17:14   #87 (permalink)
Member: 2824515
Thanks Meter: 11
cm2 dongle dead after interuption while updating fw
hello infinity team my dongle is no longer working after pc went off during updating.
i keep on getting this error(infinity dongle not connected0
here is my log on infinity dongle manager
=== DongleManager [Infinity] v1.80 [7/9/2020 19:14:06] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0000B6D17F634082
=== Process started: 7/9/2020 19:14:06 ===
Old 07-10-2020, 11:41   #88 (permalink)
Member: 327867
Thanks Meter: 12
Hello ,
i try to open CM2MT2 and recived misconfiguration error.
I read about it and try to update card and recived the log.
before update CM2MTK was running well not recive same error misconfiguration.
Contacts cleaned, driver reinstaled (pkdriver).
==== [10-Jul-20 13:10:17] ====
=== DongleManager [Infinity] v1.80 [10-Jul-20 13:10:24] ===
Searching...
Card-Reader: USB CCID Smart Card Reader 0
HWID: 00042769FF021982
Reading...
Serial No (S/N): 14752769
=== Process started: 10-Jul-20 13:10:26 ===
thanks
Old 07-10-2020, 22:10   #89 (permalink)
Member: 2684459
=== DongleManager [Infinity] v1.80 [11.07.2020 2:01:06] ===
Card-Reader: Generic EMV Smartcard Reader 2
HWID: 00000C3A21344082
Reading...
Serial No (S/N): FD500C3A
Firmware version: 0137.02
=== Process started: 11.07.2020 2:01:07 ===
Contact to /support
Old 07-10-2020, 22:24   #90 (permalink)
Member: 2684459
hello Infinity-Box CM2 error: Smart- Card misconfiguration! Contact to support!
Reading...
Contact to /support Please help me
Page generated in 0.25687 seconds with 10 queries
