07-10-2020, 23:15 | #91 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
07-10-2020, 23:16 | #92 (permalink) | |
Update dongle firmware now | |
07-10-2020, 23:17 | #93 (permalink) | |
Please fix your PC according to instruction for error #57 - https://www.infinity-box.com/support/?r=4 After that update dongle firmware with DongleManager. | |
07-12-2020, 04:35 | #96 (permalink) |
Crazy Poster Join Date: Sep 2014
Member: 2253968 Status: Offline Thanks Meter: 1 | ==== [7/12/2020 4:04:23] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.80 [7/12/2020 4:04:31] === Searching... Card-Reader: FT SCR2000 0 HWID: 0102885803EF1292 Box/Dongle is not found === DongleManager [Infinity] v1.80 [7/12/2020 4:04:35] === Searching... Card-Reader: FT SCR2000 0 HWID: 0102885803EF1292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.80 [7/12/2020 4:10:54] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102885803EF1292 === Process started: 7/12/2020 4:10:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 0/9636 Error upgrading applets: Card returned error - 0000 at 0/9636 Disconnected pls im tired of this. it is still the same error. pls help me. i have Alcor Smart Card Reader now. since its the best |
07-12-2020, 10:53 | #97 (permalink) | |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
07-12-2020, 16:14 | #98 (permalink) |
Member: 2253968 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.80 [7/12/2020 16:11:18] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0102885803EF1292 === Process started: 7/12/2020 16:11:18 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed === Process finished: 7/12/2020 16:11:34 === === DongleManager [Infinity] v1.80 [7/12/2020 16:11:34] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0102885803EF1292 Box/Dongle found: [BEST] Serial No (S/N): 6D8F8858 Firmware version: 0122.02 => Activations: - 00: Infinity-Box/Dongle v0144 - 03: [BEST] v0122 - 07: #7 => Options: - Infinity BEST - Infinity SM done...... |
07-13-2020, 22:57 | #100 (permalink) |
Major Poster Join Date: Nov 2018 Age: 38
Member: 2879612 Status: Offline Sonork: SOBARO Thanks Meter: 7 | Code: === DongleManager [Infinity] v1.80 [7/14/2020 0:33:29] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0007707219801292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 15657072 Firmware version: 0122.02 === Process started: 7/14/2020 0:33:32 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 145/8739 Error upgrading applets: Card returned error - 0000 at 145/8739 Disconnected NOW === DongleManager [Infinity] v1.80 [7/14/2020 0:46:30] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0007707219801292 === Process started: 7/14/2020 0:46:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. |
07-14-2020, 10:40 | #101 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
07-14-2020, 14:49 | #102 (permalink) | |
Freak Poster Join Date: Jul 2010
Member: 1341521 Status: Offline Thanks Meter: 37 | hi, just activate my box from a reseller. then update it and process completed after when i open CM2MT2,CM2SP2 it says Dongle Firmware version is outdated! or smart card not have active module. Quote:
07-14-2020, 21:11 | #104 (permalink) |
Member: 2879612 Status: Offline Sonork: SOBARO Thanks Meter: 7 | Thank you worked like a charm i have another question plz sir I have 2 infinity smart cards The first one S/N 2C19686D registered to sobaro. and i activated CM2 on it a while ago The other is (S/N): 15657072 Frankly speaking i lost the first smart card and my request ( if possible ) is to move activation (CM2) of S/N 2C19686D to (S/N): 15657072 Thank you in advance . |
