12-25-2020, 20:45 | #226 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: 1. Delete fault.bin file from software folder (if you have it there) 2. Install latest Infinity software updates 3. Run DongleManager 4. Update Dongle firmware Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
12-26-2020, 08:30 | #227 (permalink) | |
Junior Member Join Date: Mar 2017 Location: Ukraine/Kharkiv
Member: 2695842 Status: Offline Thanks Meter: 0 | Quote:
12-26-2020, 14:10 | #228 (permalink) | |
result ? | |
12-29-2020, 12:27 | #230 (permalink) |
Junior Member Join Date: Jul 2013 Location: ไทย
Member: 1970395 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.80 [29/12/2020 18:26:01] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001074F13114082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 9835074F Firmware version: 0146.02 === Process started: 29/12/2020 18:26:03 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
12-29-2020, 12:31 | #231 (permalink) | |
Read NOTE here - https://www.infinity-box.com/support/?s=2 Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. Please confirm that you read and understand. After that you will get a solution. waiting | |
12-29-2020, 14:19 | #232 (permalink) | |
Member: 1970395 Status: Offline Thanks Meter: 1 | Quote:
2. I just renewed | |
12-29-2020, 14:39 | #234 (permalink) | |
Please tell me that you really uninstall eltima. | |
12-29-2020, 14:41 | #235 (permalink) | |
Read NOTE here - https://www.infinity-box.com/support/?s=2 Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. Next steps: - Delete fault.bin file from software folder (if you have it there) - Run DongleManager - Update Dongle firmware | |
01-03-2021, 17:24 | #236 (permalink) |
Junior Member Join Date: Mar 2020 Location: Mozambique
Member: 2950730 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.81 [1/3/2021 18:03:44] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 1 HWID: 00006AAE200A4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 15DA6AAE Firmware version: 0146.02 === Process started: 1/3/2021 18:03:45 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to... support/?r=2 I formated PC same problem, tried in 4 PC same problem I bought credits from GSMSERVER Order details №1450692166, NOT RECEIVED since morning. All was working good, suddenly started this message Last edited by sultane faquira; 01-03-2021 at 17:29. |
01-03-2021, 17:45 | #237 (permalink) | |
Why do you use debugger and other crack tools with Infinity software ? | |
01-05-2021, 12:45 | #238 (permalink) |
Freak Poster Join Date: Aug 2008 Location: india/kolkata Age: 37
Member: 845623 Status: Offline Sonork: 100.1606036 Thanks Meter: 125 | === DongleManager [Infinity] v1.81 [1/5/2021 16:49:33] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000B0D91A224082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 1CB9B0D9 Firmware version: 0145.02 === Process started: 1/5/2021 16:49:36 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-05-2021, 14:09 | #239 (permalink) | |
Now make this: Reboot PC After that update dongle firmware with DongleManager After that delete fault.bin file (if any) Is it Ok now ? | |
01-13-2021, 04:44 | #240 (permalink) |
Insane Poster Join Date: Oct 2012 Location: Gsm World
Member: 1819074 Status: Offline Thanks Meter: 30 | === DongleManager [Infinity] v1.80 [13/01/2021 6:57:22] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 000024EB11384082 === Process started: 13/01/2021 6:57:22 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
