Old 12-23-2020, 16:34   #196 (permalink)
Member: 2729037
Thanks Meter: 8
DongleManager [Infinity] v1.80 [12/23/2020 17:29:05] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 00012F341F444082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): E9A32F34
Firmware version: 0146.02
=== Process started: 12/23/2020 17:29:07 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Write to https://www.infinity-box.com/support/?r=2
Old 12-23-2020, 19:43   #197 (permalink)
Member: 1043909
Thanks Meter: 60,911
Originally Posted by muksforu View Post
i tyr but result is same
driver version 2.5.9.1202
=== DongleManager [Infinity] v1.80 [23-12-2020 20:26:51] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: FT SCR2000 0
HWID: 0102A6621C6A1292
=== Process started: 23-12-2020 20:26:51 ===
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Try now with another PC or another card-reader (dongle)
Result ?
Old 12-23-2020, 19:44   #198 (permalink)
Member: 1043909
Searching...
Reading...
Hi,
Make step-by-step now:
Reboot PC
then update dongle firmware
then delete fault.bin file from CM2 folder (if any)
Old 12-23-2020, 23:18   #199 (permalink)
Member: 2471057
=== DongleManager [Infinity] v1.80 [23/12/2020 22:43:12] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 00000EA30EFE4082
Reading...
Serial No (S/N): B1400EA3
=== Process started: 23/12/2020 22:43:14 ===
Old 12-23-2020, 23:20   #200 (permalink)
Member: 148515
Thanks Meter: 19,534
Searching...
Reading...
Hello,
Please upload file fault.bin to mega.nz and post link here.
File is in /InfinityBox/CM2MT2/ or in /InfinityBox/CM2SP2/ folder
Old 12-24-2020, 06:42   #201 (permalink)
Member: 2541717
Thanks Meter: 2
=== DongleManager [Infinity] v1.80 [24-Dec-20 13:15:22] ===
HWID: 000020EB7CEC4082
Reading...
Serial No (S/N): CAA520EB
=== Process started: 24-Dec-20 13:15:24 ===
i already deleted fault.bin stay that please help
Old 12-24-2020, 08:36   #202 (permalink)
Member: 2203321
Thanks Meter: 46
=== DongleManager [Infinity] v1.80 [24/12/2020 7:27:38] ===
Box/Dongle type selected: [BEST]
HWID: 0105657524881292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): F9DF6575
Firmware version: 0122.02
=== Process started: 24/12/2020 7:27:39 ===
Old 12-24-2020, 10:39   #203 (permalink)
Member: 2471057
Hello,
i delete this file yesterday !!!!!!
Old 12-24-2020, 12:10   #204 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Reading...
Hello,
Next time do not delete file because file has info HOW TO FIX YOUR PC !!!
Now Read NOTE here - https://www.infinity-box.com/support/?s=2
Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software.
Next steps:
- Delete fault.bin file from software folder (if you have it there)
- Run DongleManager
- Update Dongle firmware
Old 12-24-2020, 12:11   #205 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Reading...
Reboot PC
After that Update dongle firmware with DongleManager
result ?
Old 12-24-2020, 12:13   #206 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
yup... as we expect.
Please explain Why do you use debugger and other crack tools with Infinity software ?
Old 12-24-2020, 12:47   #207 (permalink)
Member: 2622185
Sonork: 100.1675196
Thanks Meter: 19
what is the solution
HWID: 0000A6D4217A4082
=== Process started: 12/24/2020 16:44:47 ===
Old 12-24-2020, 13:49   #208 (permalink)
silivriserdar's Avatar
Member: 2291790
Thanks Meter: 45
=== DongleManager [Infinity] v1.80 [24.12.2020 15:48:55] ===
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 000057BB00001942
Reading...
Serial No (S/N): 4B1E57BB
Firmware version: 0143.02
=== Process started: 24.12.2020 15:48:58 ===
Contact to http://www.infinity-box.com/support/?r=2
Old 12-24-2020, 14:34   #209 (permalink)
Member: 2471057
No i never use crack tools
i have eft pro and z3x and cm2
when i update cm2, eft pro and z3x was conected
may be this is the problem
Old 12-24-2020, 14:36   #210 (permalink)
Member: 130995
Thanks Meter: 35,227
eft pro and z3x gives not problem like you got.
What kind of debugger do you use ?
Page generated in 0.27561 seconds with 9 queries
