Old 01-13-2021, 11:14   #241 (permalink)
Member: 1043909
Thanks Meter: 58,034
Originally Posted by bellosule View Post
=== DongleManager [Infinity] v1.80 [13/01/2021 6:57:22] ===
Box/Dongle type selected: [BEST]
Card-Reader: FT SCR2000 0
HWID: 000024EB11384082
=== Process started: 13/01/2021 6:57:22 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Write to https://www.infinity-box.com/support/?r=2
Hello,
- Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6
File with Drivers: CardReader_Fetian_FT2K.7z
File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
- Run Infinity DongleManager
- Update Dongle firmware
Alternative method:
- Insert Infinity Smart-Card into another Card-Reader (f.e. another dongle or box). Good result for today gives Alcor Card-Reader.
In case of problem DO NOT update card again but contact to support !
More info is here - https://www.infinity-box.com/support/?r=100129
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 03-17-2021, 11:48   #242 (permalink)
Member: 2879612
Sonork: SOBARO
Thanks Meter: 3
=== DongleManager [Infinity] v1.81 [3/17/2021 12:41:58] ===
Box/Dongle type selected: Infinity [BEST]
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0104686D04701292
Box/Dongle found: Infinity [BEST]
Reading...
Serial No (S/N): 2C19686D
Firmware version: 0122.02
=== Process started: 3/17/2021 12:41:59 ===
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing check error:
Server answer:[0002] Client/Server protocol packet length is invalid.
Write to ..
Now i get this
=== DongleManager [Infinity] v1.81 [3/17/2021 12:45:00] ===
Searching...
Box/Dongle is not found
Thanx in advance !
Old 03-17-2021, 14:30   #243 (permalink)
Member: 1043909
Reading...
Securing session...
Session secured ok
Upgrading dongle...
Applet upgrade ok
Write to ..
Now i get this
Searching...
Thanx in advance !
Hello,
This dongle was reported by owner as lost. Please contact to your seller to discuss.
Old 03-17-2021, 15:03   #244 (permalink)
Member: 2879612
Sonork: SOBARO
Thanks Meter: 3
Originally Posted by YellowBoss View Post
Hello,
Thats correct sir , i am the owner and i lost smart card before inside my shop so i request to move cm2 activation to my another card , and now i found it . if there is a way to activate it back just as best bb5 for Nokia then i will be grateful as i have more than 2 workers inside my shop . if no way then no worries . thank you anyways you already gave us lots before !
Old 03-17-2021, 17:18   #245 (permalink)
Member: 1043909
Hello,
Please contact to support the same way as reported dongle as lost and it will be fixed same day.
Old 03-29-2021, 08:26   #246 (permalink)
Member: 289669
=== DongleManager [Infinity] v1.81 [29-Mar-21 12:08:25] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0000D4BF00001942
Box/Dongle found: Infinity-Box/Dongle [CM2]
Reading...
Serial No (S/N): 7206D4BF
Firmware version: 0147.02
=== Process started: 29-Mar-21 12:08:29 ===
Server answer:[0031] Dongle identification data damaged.
Last edited by farhan_latif; 03-29-2021 at 08:27. Reason: pls help me to solve this problem
Old 03-29-2021, 11:57   #247 (permalink)
Member: 1043909
Searching...
Reading...
Hello,
1. Read NOTE - https://www.infinity-box.com/support/?s=2
2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software.
3. Update dongle with Infinity DongleManager.exe
4. Delete fault.bin file (if you have it in CM2 folder)
5. Run Infinity exe
Old 03-30-2021, 20:00   #248 (permalink)
Member: 2959226
DongleManager [Infinity] v1.81 [2021/03/29 15:55:46] ===
Box/Dongle type selected: Infinity-Box/Dongle [CM2]
HWID: 00011AD6212B4082
Reading...
Serial No (S/N): 27071AD6
=== Process started: 2021/03/29 15:55:47 ===
Server answer:[0031] Dongle identification data damaged. plz help
Old 03-30-2021, 20:23   #249 (permalink)
Member: 327704
Thanks Meter: 45
hi team. please need help. i can't open huatool. smart card failure(4). smart-card was curropted! activated with infinity box. hua team ask me to contact infinity team
Old 03-30-2021, 21:38   #250 (permalink)
Member: 1043909
Reading...
Hello,
5. Run Infinity exe
Old 03-30-2021, 21:38   #251 (permalink)
Member: 1043909
Hi,
What is the Infinity S/N?
Old 03-31-2021, 10:57   #252 (permalink)
Member: 327704
Thanks Meter: 45
Hi,
Serial No (S/N): 9F0A2670
Old 03-31-2021, 11:03   #253 (permalink)
Member: 1043909
Update dongle firmware now with Infinity DongleManager.
Is it Ok now?
Old 03-31-2021, 11:28   #254 (permalink)
Member: 327704
Thanks Meter: 45
Is it Ok now?
yes, it is ok. thank you very much. but I will like to know what happens to avoid it next time
Old 03-31-2021, 12:53   #255 (permalink)
Member: 1043909
It's some kind of unpredictable issue. If you will have the same issue again in future just contact us once again.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.22636 seconds with 8 queries
