01-05-2018, 02:40 | #2716 (permalink) |
Major Poster Join Date: Feb 2002 Location: POLAND
Member: 9571 Status: Offline Thanks Meter: 7 | Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.70 [05.01.2018 02:11:18] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000DA86FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 0D92DA86 Firmware version: 0136.02 === Process started: 05.01.2018 02:11:22 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
01-05-2018, 11:40 | #2717 (permalink) |
Insane Poster Join Date: Nov 2014 Location: PAKISTAN LAHORE Age: 27
Member: 2285351 Status: Offline Sonork: ali sarwar 200 Thanks Meter: 2 | Please Fix my Problem. === DongleManager [Infinity] v1.72 [1/5/2018 15:38:34] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0101878220281292 Box/Dongle found: [BEST] Reading... Serial No (S/N): ED8E8782 Firmware version: 0122.02 === Process started: 1/5/2018 15:38:36 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
01-05-2018, 11:41 | #2718 (permalink) |
01-05-2018, 20:08 | #2720 (permalink) |
Member: 9571 Status: Offline Thanks Meter: 7 | === DongleManager [Infinity] v1.72 [05.01.2018 20:06:40] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000DA86FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 0D92DA86 Firmware version: 0136.02 === Process started: 05.01.2018 20:06:44 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Card-Reader: Gemalto e-gate Smart Card 0 ATR: 3B759400006202020201 Card Manager: A0000000030000 SerialNumber: 0000DA86 ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 6021 Serial Number: 0000DA86 Batch Identifier: FF02 Module Fabricator: 1982 Module Packaging Date: 6021 IC Card Manufacturer: 1983 IC Em******* Date: 6021 Pre Personalizer: 1984 Pre Personalization Date: 6021 Pre Personalization Equipment Identifier: 00030001 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 0000DA86FF021982 Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) Last edited by Bodek; 01-05-2018 at 20:15. Reason: InfinityHelp help plese, Bodek |
01-05-2018, 22:53 | #2721 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
01-05-2018, 22:54 | #2722 (permalink) | |
you must think before write ! | |
01-05-2018, 22:55 | #2724 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware | |
01-05-2018, 22:57 | #2725 (permalink) | |
Why do you use debugger and other crack tools with Infinity software ? | |
01-05-2018, 22:58 | #2726 (permalink) | |
01-06-2018, 10:14 | #2728 (permalink) |
Member: 2285351 Status: Offline Sonork: ali sarwar 200 Thanks Meter: 2 | plz team solve my problem i.m create many post on froum but team no respons thanks in advance i hop you solve my problm Infinity team Last edited by Ali sarwar 200; 01-06-2018 at 10:16. Reason: bb |
01-06-2018, 11:36 | #2729 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2164476 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.70 [1/6/2018 16:34:05] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000EB4712BF4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): BE37EB47 Firmware version: 0136.02 === Process started: 1/6/2018 16:34:06 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Dongle misconfiguration |
01-06-2018, 17:02 | #2730 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | Serial No (S/N): 62499E81 === DongleManager [Infinity] v1.72 [1/6/2018 15:57:58] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01049E81147D1292 === Process started: 1/6/2018 15:58:00 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
