10-16-2020, 20:05 | #4 (permalink) |
Freak Poster Join Date: May 2020 Location: Globe
Member: 2955840 Status: Offline Thanks Meter: 83 | not supported for now. here is my log from box. Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM107) MODE : BOOTROM PORT : 107 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL Info : Device is not supported yet! Reconnect Power/Cable! I dont have choice than to use hand. |
10-16-2020, 21:33 | #5 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
10-16-2020, 22:07 | #6 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 322130 Status: Offline Thanks Meter: 57 | Operation : Reset Settings/Format FS [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
10-17-2020, 05:10 | #7 (permalink) |
Member: 2955840 Status: Offline Thanks Meter: 83 | The job is done already.I have to post log so that you will be convinced. Here is how I did mine. 1) To factory reset Ta-1206 put device in fastboot mode by plugging in usb to the phone and hold power and down button then use Infinity-Box Ast set mode to recovery the phone will display no command. Then power and volume + button to enter recovery. That's all. incase of frp the person can use languages method or click policy on policy long pressed any word there option will pop up like copy,share and the rest.though,its for advance people in the game. |
The Following User Says Thank You to Chijohn For This Useful Post: |
05-27-2021, 13:32 | #12 (permalink) | |
Insane Poster Join Date: Jul 2018
Member: 2850574 Status: Offline Thanks Meter: 8 | Quote:
