06-16-2020, 09:26 | #541 (permalink) | |
Attach here fault.bin file from Infinity software folder. | |
06-16-2020, 10:40 | #543 (permalink) | |
To solve problem completely attach here fault.bin file from Infinity software folder. it's in folder with software you run last time. Waiting for the file ! | |
06-16-2020, 10:41 | #544 (permalink) |
Junior Member Join Date: Feb 2010 Location: ahmedabad Age: 38
Member: 1234470 Status: Offline Sonork: 100.1590120 Thanks Meter: 20 | infinity box error === DongleManager [Infinity] v1.80 [16/06/2020 15:08:25] === Searching... Card-Reader: Generic EMV Smartcard Reader 1 HWID: 000131381F444082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): FA3B3138 Firmware version: 0143.02 === Process started: 16/06/2020 15:08:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
06-16-2020, 10:50 | #545 (permalink) | |
There is a software conflict with the next application: \program files (x86)\intel\bluetooth\devmonsrv.exe \program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe \program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe \program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Disable this process - delete fault.bn file - update dongle firmware with DongleManager now and then run Infinity software. | |
06-16-2020, 11:00 | #546 (permalink) |
Member: 1234470 Status: Offline Sonork: 100.1590120 Thanks Meter: 20 | same problem sir === DongleManager [Infinity] v1.80 [16/06/2020 15:28:24] === Searching... Card-Reader: Generic EMV Smartcard Reader 1 HWID: 000131381F444082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): FA3B3138 Firmware version: 0144.02 === Process started: 16/06/2020 15:28:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
06-16-2020, 11:10 | #547 (permalink) | |
Thank you for your IGNORANCE ! attach fault.bin file here now | |
06-16-2020, 11:28 | #548 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
delete it, reboot PC then delete fault.bin then update card run Infintiy | |
06-16-2020, 11:48 | #549 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: swat
Member: 879965 Status: Offline Thanks Meter: 31 | Quote:
There is no any file with the name of fault.bin in my infinity installed folder. Please sir help me and solve my problem asap Thanks in advance | |
06-16-2020, 11:52 | #550 (permalink) | |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | Quote:
No sir; my support is still active Registered: 11-May-2017; Expired: 24-Oct-2021; Support: Active | |
06-16-2020, 12:02 | #554 (permalink) | |
There is a software conflict with the next application: \program files (x86)\intel\bluetooth\devmonsrv.exe \program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe \program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe \program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe \program files\via xhci uasp utility\usb3monitor.exe Delete or rename files (see above) do it and tell me what files was deleted. waiting | |
06-16-2020, 12:03 | #555 (permalink) | |
Youre right service expired, thank you sir. | |
