Old 01-28-2020, 18:26   #46 (permalink)
Member: 1043909
Thanks Meter: 57,251
Originally Posted by yuranc8 View Post
=== DongleManager [Infinity] v1.72 [1/28/2020 17:54:16] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 000226E000001942
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 9EF826E0
Firmware version: 0128.02
=== Process started: 1/28/2020 17:54:18 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Applet upgrade ok
Identification check error: Applet Authentication
Socket Error # 10054
Connection reset by peer.
Hi,
Try once again now
Old 01-28-2020, 18:33   #47 (permalink)
Member: 1043909
Originally Posted by ntsnpr View Post
=== DongleManager [Infinity] v1.72 [1/28/2020 17:50:49] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0000BED21A224082
Reading...
Serial No (S/N): 371CBED2
Firmware version: 0137.02
=== Process started: 1/28/2020 17:50:50 ===
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Contact to http://www.infinity-box.com/support/?r=2
my fault.bin file is in the link : https://mega.nz/#!vUFnkIBb!XnnHA4gnC...CKs1fxgE8FC0UQ
i know exactly what is my fault which is not the infinity team or my hard ware fault "simply i use ida, flexhex ollydbg and many other debuggers but not for cracking ur software aka cm2 or infinity dongle software.. kindly if it is possible fix it for me .
2nd i know that iam out of support even without this issue ..
but still trust that you guys wont mind to fix it if it is possible
thanks for reading and sorry for bothering .
Update it now.
Please be noted that next time the same issue can not be fixed
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 01-28-2020, 19:27   #48 (permalink)
Member: 340450
Thanks Meter: 2
Thumbs up thx
Originally Posted by YellowBoss View Post
Update it now.
many thanks to you and the rest of infinity team for fast respond
it works as new and perfectly after updating sim fw here is the log
=== DongleManager [Infinity] v1.72 [1/28/2020 20:23:50] ===
Searching...
Reading...
=== Process started: 1/28/2020 20:23:51 ===
Securing session...
Session secured ok
Upgrading dongle...
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing ok
Process completed
=== Process finished: 1/28/2020 20:24:10 ===
=== DongleManager [Infinity] v1.72 [1/28/2020 20:24:10] ===
=> Activations:
- 00: Infinity-Box/Dongle v.0137
- 07: #7
Old 01-28-2020, 21:47   #49 (permalink)
Member: 340450
Thanks Meter: 2
*note i cant upload the fault.bin here since the forums just gives err kindly put email address if ur going to ignore my external link .
problem solved by infinity team support ty peeps
Old 01-29-2020, 07:47   #50 (permalink)
Member: 1195673
Sonork: rehanisrar
Thanks Meter: 2
not solve help plz
Hello,
Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - https://www.infinity-box.com/support/?r=6
OR
Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
- run DongleManager
- update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
==== [1/29/2020 11:39:59] ====
Smart-Card update process may takes up to 4-5 minutes to complete.
During update process software may seem hanging but please DO NOT close or terminate forcely application.
It may cause harm to your Smart-Card. Just let the process to be finished.
- Connect Infinity Box/Dongle (Smart-Card) to PC
- Disconnect all other Boxes/Dongles (Smart-Card) from PC
- Update Smart-Card Reader drivers to latest version
- Disable Antivirus and Firewall
- DO NOT interrupt update process even if you think that software is freez !
=== DongleManager [Infinity] v1.72 [1/29/2020 11:40:02] ===
Searching...
Card-Reader: FT SCR2000 0
HWID: 0102827B10321292
Box/Dongle is not found
=== DongleManager [Infinity] v1.72 [1/29/2020 11:40:10] ===
Searching...
Select Token Type: instead of Autodetect
=== DongleManager [Infinity] v1.72 [1/29/2020 11:40:30] ===
Box/Dongle type selected: [BEST]
=== Process started: 1/29/2020 11:40:30 ===
Securing session...
Session secured ok
Upgrading dongle...
Last APDU: 133 sec
Card returned error - 0000 at 29/10169
Error upgrading applets:
Disconnected
Old 01-29-2020, 08:07   #51 (permalink)
Member: 1043909
Searching...
Searching...
Securing session...
Session secured ok
Upgrading dongle...
Last APDU: 133 sec
Disconnected
You must install special drivers as per instruction.
Have you instaled it ?
Old 01-29-2020, 08:20   #52 (permalink)
Member: 1195673
Sonork: rehanisrar
Thanks Meter: 2
yes sir install
yes install sir am use best dongle
cm2 activation expire 15/1/2020
Old 01-29-2020, 09:04   #53 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 186
My dongle temporary blocked. What i wanna do?
=== DongleManager [Infinity] v1.72 [2020-01-29 12:58:30] ===
HWID: 0107A48320281292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): 9619A483
Firmware version: 0122.02
=== Process started: 2020-01-29 12:58:31 ===
Server answer:[0006] Your account is temporary suspended.
See problem reason in log file
Old 01-29-2020, 09:22   #54 (permalink)
Member: 1043909
I talk about smart card drivers but not about activation date !
do you understand the diference ?
what is the installed FT2000 drivers version ?
Old 01-29-2020, 09:24   #55 (permalink)
Member: 1043909
you must move Fenix card reader to trash and insert smart-card into another card reader.
Please cofirm that fenix reader is in trash, you will get new instruction then.
Old 01-29-2020, 09:30   #56 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 186
ok.. its in trash sir... never touch again with infinity card. now i have
this one. Is it ok? How to proceed?
Old 01-29-2020, 09:44   #57 (permalink)
Member: 1195673
Sonork: rehanisrar
Thanks Meter: 2
sir
2.5.9.1202 version install sir
Old 01-29-2020, 09:45   #58 (permalink)
Member: 1043909
as I can see you tried to kill your card with fenix reader many times, in year 2016, 2017 and later so it may be you killed your card. You was warned long time ago http://forum.gsmhosting.com/vbb/f296...-open-2269169/ and probably earlier.
now update dongle with other reader, maybe it can be updated
Old 01-29-2020, 09:48   #59 (permalink)
Member: 1043909
I suggest you do not update dongle again and again withourt support approval, the only result of your non-stop tries will be killed card. If it's your aim - please continue.
do you have another card-reader ?
Old 01-29-2020, 09:51   #60 (permalink)
Member: 1195673
Sonork: rehanisrar
Thanks Meter: 2
plz
nck dongle not infinity card reader extra any suggest programme not work sir
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.25671 seconds with 8 queries
