01-25-2021, 15:18 | #76 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | https://mega.nz/file/Vk0iRJqa#WNE5qU...C3DwEhM1kc-cJ8 |
01-25-2021, 16:01 | #77 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What is your final result ? | |
01-28-2021, 20:43 | #78 (permalink) |
Major Poster Join Date: Apr 2016
Member: 2557274 Status: Offline Thanks Meter: 15 | help === DongleManager [Infinity] v1.81 [1/28/2021 10:23:36] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000109991FDD4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): F26E0XXX Firmware version: 0147.02 === Process started: 1/28/2021 10:23:37 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 === DongleManager [Infinity] v1.81 [1/28/2021 10:25:38] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000109991FDD4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): F26E0XXX Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle [CM2] v0147 - 03: Infinity [BEST] v0122 => Options: - Infinity-Box/Dongle [CM2] - Infinity [BEST2] |
01-28-2021, 20:48 | #79 (permalink) | |
1. reboot PC 2. update dongle with Infinity DongleManager.exe 3. delete fault.bin file (if you have it in CM2 folder) NOTE: Always close boot-helper installation package before run Infinity CM2MT2 ! | |
02-17-2021, 18:40 | #81 (permalink) | |
Update it now. Do not use any kind of debugger with Infinity any more otherwise card can be damaged permanently. | |
02-18-2021, 10:16 | #82 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 195 | Please help my cm2 not open show smart-card misconfiguration . please help and give me solution please.... === DongleManager [Infinity] v1.80 [2/18/2021 15:12:29] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0101948820281292 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): CE1A9488 Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 30 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle v0147 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM |
02-18-2021, 10:58 | #83 (permalink) | |
Update it now with Infinity DongleManager. What is the result ? | |
02-18-2021, 12:15 | #85 (permalink) |
Junior Member Join Date: Nov 2008
Member: 908510 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.81 [18/2/2021 18:13:54] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00001AC30EFE4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): B62E1AC3 Firmware version: 0147.02 === Process started: 18/2/2021 18:13:55 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to |
02-18-2021, 12:54 | #86 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: 1. Delete fault.bin file (if you have it in CM2 folder) 2. Install latest Infinity software updates 3. Run DongleManager 4. Update Dongle firmware Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
02-26-2021, 11:28 | #87 (permalink) |
Insane Poster Join Date: Oct 2017 Location: Chandrapur
Member: 2773273 Status: Offline Sonork: no Thanks Meter: 28 | === DongleManager [Infinity] v1.81 [26-Feb-21 15:40:32] === Searching... Card-Reader: FT SCR2000 0 HWID: 000017B218164082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): 3C7617B2 Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle [CM2] v0147 - 07: #7 => Options: - Infinity-Box/Dongle [CM2] - Infinity SM MY DONGLE SHOWING misconfiguration please solve my problem |
02-26-2021, 14:14 | #88 (permalink) | |
02-28-2021, 13:28 | #89 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Russia
Member: 1434572 Status: Offline Sonork: 100.1605127 Thanks Meter: 49 | Hi Can you help with my probem? during use CM2MT2 software auto closed and after that dongle misconfiguration === DongleManager [Infinity] v1.81 [28.02.2021 15:20:54] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00043695FF021982 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 40123695 Firmware version: 0147.02 === Process started: 28.02.2021 15:20:58 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
02-28-2021, 19:29 | #90 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: 1. Delete fault.bin file (if you have it in CM2 folder) 2. Install latest Infinity software updates 3. Run DongleManager 4. Update Dongle firmware | |
