Old 05-06-2015, 16:19   #1 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 527
MT6571 nand read error
Card found: S/N 334F:0128
Chinese Miracle II  [MTK module] v 1.18
 Operation : Check / Read Info [ v1.18 ]
 Wait for phone...
Phone found! [ 13 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001500010000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
DA Sent. Configure setting now ...
 DA start Failed!
Check battery , cable , drivers and try try again
 Boot Error!
 Operation Failed
Elapsed: 00:00:14
Reconnect Power/Cable!
 Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : CA00
BLVersion : 0x01
BromVersion : 0x00
BLVersion : 0x00
Preloader Status : Not active (Erased)
Processing DA stage
 Error : Correct DA sequence not found for target!
Try Re-Install CM2MTK module!
 Boot Error!
 Operation Failed
Elapsed: 00:00:16
 Wait for phone...
Phone found! [ 13 ]
Sync...
Brom Init not done
Boot Error!
 Operation Failed
Elapsed: 00:00:06
 Wait for phone...
Phone found! [ 13 ]
Sync...
Error while getting CPU info, sync error!
Boot Error!
 Operation Failed
Elapsed: 00:00:08
 Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0085 , [TOSHIBA] TYBC0A111557KC
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
INT RAM    : 0x00020000
EXT RAM    : 0x10000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
 NAND : Detecting structure now... Please, wait.
NAND : Structure detect failed [1F]! Send report to support!
 Info read not done :( Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
 Done!
Elapsed: 00:01:47
Old 05-06-2015, 16:44   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Try with other Nand init settings.
Br.
Old 05-06-2015, 18:16   #3 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 527
Thanks for help
problem solved by selecting P3 init nand mod
 Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 [AP] : Initial info read Ok!
 Done!
Elapsed: 00:00:11
Operation : Format FileSystem [ v1.18 ]
 Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA Stat : v0.2 on BBID : 0x8B
SOC VERIFY : C1
Boot Ok!
Format : UserData Only (Factory Reset)
 Format UDA block
Format block Ok!
 Done!
Elapsed: 00:00:14
Phone works very well
Thanks
Page generated in 0.15045 seconds with 8 queries
