07-25-2009, 17:51 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: france Age: 43
Member: 183437 Status: Offline Thanks Meter: 97 | some info on MyWay touch ! myway touch.jpg myway touch pins.JPG myway touch read flash.JPG what model i ve to select please to read flash, in order to get it supported for unlock B.R |
The Following User Says Thank You to kimo59 For This Useful Post: |
07-25-2009, 18:04 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use ChineseMiracle software, select model "MT6228..." and read firmware. Please, upload firmware backup to http://rapidshare.com and send link to [email protected] |
07-25-2009, 19:54 | #3 (permalink) |
Member: 183437 Status: Offline Thanks Meter: 97 | firmware sended to support ..... thx Last edited by InfinitySupport; 07-25-2009 at 20:23. Reason: link with rapidshare killcode deleted |
07-25-2009, 20:16 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thanks, downloading file now. You can try to make this method right now for unlock: 1. run ChineseMiracle 2. go to "Service" page 3. make unlock via "read codes" or make unlock by "smart fast" method Please, post here operation log If phone can not be unlocked we will check logs, this may helps to make unlock solution faster. |
07-26-2009, 09:31 | #5 (permalink) |
Member: 183437 Status: Offline Thanks Meter: 97 | Hello,COM8 [VCP0] selected module v2.85 Action: unlock unlock method: smart fast Model: Autodetect 6228-6230 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:482D:0101 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: MAUI.07A.W07.28.MP.V22.F2 Version: EZIO28_07A_HW detecting structure #2... 0 done 44 byte(s) read imei: 35302003018047 connection Ok detecting structure #1... 0 3 4 5 6 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31error: detection failed (29 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 116 sec Remove/Install battery now ! COM8 [VCP0] selected module v2.85 Action: read codes unlock method: read codes Model: Autodetect 6228-6230 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:482D:0101 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: MAUI.07A.W07.28.MP.V22.F2 Version: EZIO28_07A_HW detecting structure #2... 0 done 44 byte(s) read imei: 35302003018047 connection Ok detecting structure #1... 0 3 4 5 6 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31error: detection failed (29 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 129 sec Remove/Install battery now ! |
07-27-2009, 19:36 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use this new test software: http://www.infinity-box.com/download...dule_v2.83.rar Please, try to unlock phone by different unlock methods, let's see results. |
07-27-2009, 20:56 | #9 (permalink) |
Member: 183437 Status: Offline Thanks Meter: 97 | Hello, Fast update thx unlocked first try COM8 [VCP0] selected module v2.83 Action: unlock unlock method: smart fast Model: MyWay-Touch Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6228:8A02:8A02]... CPU: MT6228 chip: 0031:482D:0101 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: MAUI.07A.W07.28.MP.V22.F2 Version: EZIO28_07A_HW 44 byte(s) read imei: 35302003018047 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 56 sec Remove/Install battery now ! B.R |
The Following 4 Users Say Thank You to kimo59 For This Useful Post: |
07-29-2009, 01:20 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Pinout is in first post in current thread. connector L18B 1x18 Rx: 13 Tx: 12 Just check with multimeter where is GND at phone connector. Please, post here your experience with pinout and unlock process. |
some info on GHT G3 ! | kimo59 | Infinity-Box | 10 | 07-16-2011 09:41 |
some info on ZTE g-N281 / SFR 343 ! | kimo59 | Infinity-Box | 62 | 03-26-2011 06:49 |
Need Some Info on MYC-2 Newbee | Longly600 | ARM9 BASED M62 / M62+ | 0 | 03-14-2005 17:47 |
SOME INFO ON DEJAN HEX | GSMWIZARD | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 02-12-2002 23:25 |
