12-30-2008, 16:10 | #1 (permalink) |
Insane Poster Join Date: Jan 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 441483 Status: Offline Thanks Meter: 6 | Somebody Help me...please i need firmware for Ktouch A905....TM927_PCB04_GPRS_MT6228_S02.092710_670_V00 31.BIN i have dead phone now.... Please.... |
12-30-2008, 17:47 | #6 (permalink) |
Member: 441483 Status: Offline Thanks Meter: 6 | I try to use it...but still error... COM3 [VCP0] selected module v2.73 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN ver. sw 2: 092710_670_V0031, 4A004E0F ffs offset/size: 01900000/02700000 id-page1 Ok nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: 98F18095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 0098:00F100800095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... reading structure area... detecting structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN ver. sw 2: 092710_670_V0031, 4A004E0F ffs offset/size: 01900000/02700000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB.[TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F 0B1FFB5].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB._TM92 7_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F0B1F FB5_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F 0B1FFB5].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB._TM927_PCB04_GPRS_MT6228_S02.092710_670 _V0031.BIN_F0B1FFB5_.rpl ==================== warning: unknown identification#1 structure: TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F 0B1FFB5 error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN - make "Read detailed information" operation - send "system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? Identification Done Write ... write core area 1 of 2... write core area 2 of 2... error: code: A500000BF1 error: code: 5A error: code: A500 error: code: error: block/offset: 000002D5/002D5000 error: can't write nand core Write Fail Finished, time used: 896 sec Remove/Install battery now ! |
12-30-2008, 18:24 | #7 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | check on support ... there are Lot of firmwares available on support by infinity Team TM927_PCB04_GPRS_MT6228_S02 jast look like a serch |
12-31-2008, 08:18 | #8 (permalink) |
Member: 441483 Status: Offline Thanks Meter: 6 | I try to use this file from support but still error...... TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031__64m_ En_Cn.B4M.bin TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031__128m _En_Cn.B4M.bin Firstable...the phone restarted....i do wrong procedure...format whole chip....and then the phone dead.... Maybe somebody can give me soulution...... BR |
01-02-2009, 10:58 | #10 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | well its the Comprehensive way to find the file : http://forum.gsmhosting.com/vbb/showthread.php?t=499453 if still no luck than u need the Phone same alike ..then read and just do your work ... |
Could somebody help me please? | Elizabeth92 | Samsung Flashers, Software, Firmware. | 4 | 02-12-2008 08:52 |
can somebody help me please | mickb9455 | CAR Electronics | 0 | 07-23-2007 18:56 |
Somebody Help Me PLEASE | bobby5 | Old Ericsson Phones & Sony Phones | 2 | 07-23-2000 17:34 |
Somebody Help Me PLEASE | bobby5 | Motorola Old Legacy (EMMI) | 0 | 07-22-2000 16:44 |
