Old 02-11-2017, 12:54   #1 (permalink)
Member: 2087773
Thanks Meter: 11
someone can't help me,... how to fix my problem?...
my problem
======= Flash
Files set for flashing :
[ MCU ] : MT6755__OPPO__CPH1605__CPH1605EX_11_A.06_161219__A ndroid_5.1.ispff
Wait for phone...
Phone found! [ 34 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from ScatFW!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A410B464F2A3DB
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xAA2AA7499FCE2F744E34FE7D3235D68E
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
USBDL : Init HSUSB Ok!
ISPFF ID : 6755 , TARGET ID : 6755
Flash pre-erase disabled
Write Flash now ...
Init Ok , Sending blocks ...
Prepare failed
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 34 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : oppo6750_16021 , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Disabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Main PMT update failed!
Operation Failed
Elapsed: 00:00:21
How to fix that?....
Old 02-11-2017, 14:48   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
What was phone initial condition? Make FlashIC Test.
Br.
Infinity Box Team.
Old 02-26-2017, 16:02   #3 (permalink)
Registered User
Member: 830204
Thanks Meter: 21
my problem
======= Flash
Wait for phone...
Phone found! [ 34 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Write Flash now ...
Prepare failed
Flash Error!
Operation Failed
Elapsed: 00:00:19
======= Flash
Wait for phone...
Phone found! [ 34 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Build new PMT ...
Update Primary ...
Operation Failed
Elapsed: 00:00:21
Noone can help with this problem CM2 also cannot help us
Page generated in 0.13613 seconds with 8 queries
