Old 03-31-2009, 09:01   #1 (permalink)
Member: 1128
Thanks Meter: 13
8800е-1-carbon-RM233
I need this flash: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN
I flash phone because i have problem with saving photos and received files.
I flash phone with all flashes from support area but not result (blinking LCD or mirror image).
By mistake i haven't backup.
Thanks in advance.
Old 03-31-2009, 09:20   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thanks in advance.
Hello,
If required file can not be found in support area (please use "search" function in support area first)
it will be good if somebody can read full flash from the same good working phone and send
full flash backup to [email protected] so we will be able to prepare and upload
good working files in support area for all users.
Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-31-2009, 09:36   #3 (permalink)
Star75's Avatar
Member: 53198
Sonork: 100.1589499
Thanks Meter: 819
Thanks in advance.
Wait i will read full back up from good phone and upload for you
Old 03-31-2009, 11:02   #4 (permalink)
Member: 201963
I same need this flash: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN-8800e-1-RM233-carbon
Old 03-31-2009, 12:38   #5 (permalink)
Star75's Avatar
Member: 53198
Sonork: 100.1589499
Thanks Meter: 819
8800е-1-carbon-RM233 have about 10 different models, using the same firmware version (H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2 _0TMC1_26B).
But can't be writed for each other,phone will be can't power on ,blinking LCD or mirror image...
Here the first please test
The Following User Says Thank You to Star75 For This Useful Post:
Old 03-31-2009, 21:06   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i will upload above software to our support area collection.
Old 04-03-2009, 18:05   #7 (permalink)
Member: 201963
Thanks Star75,after flashing this flash,phone power on,no LCD
Old 04-03-2009, 18:12   #8 (permalink)
Member: 201963
Picters my phone
http://www.4shared.com/account/dir/1...ng.html?rnd=33
details phone
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: KP26_06B_HW
Software version: P02_SP_SSD_NB0_1.2.0
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 352935895304724
Finished, time used: 4 sec
Power off phone now !
Old 04-03-2009, 21:03   #9 (permalink)
Crazy Poster
Member: 798784
Thanks Meter: 6
Same problem.No lcd,white sreen,vibro 5-10 seconds after touch any key.Pleas help somebody.8800e-1 rm-233 6226ba S71PL127N
Old 04-05-2009, 11:32   #10 (permalink)
Member: 148515
hello milkonym & voffka05!
what was you phone Original software version?
i think it was not that which posted mr. Star75
you can find this in operation.log file:
you must open with notepad operation.log file which is located in Chinese Miracle folder.
scrool it from up from end and find First operation with this phone.
there you will see Original software version.
also helpfull in search is date/time stamp
Old 04-06-2009, 07:38   #11 (permalink)
Member: 201963
8800e-1-carbon-RM233
Hello,Infinity Team,
first operation with this phone
==== log: [23/3/09 13:24:46] ====
COM20 [VCP0] selected
module v2.76
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:4BCA:4281
status: FF
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN
ver. sw 2: P02_SP_SSD_NB0_1.2.0TMC1_26B, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN]_20090323-133104.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 421 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-06-2009, 07:43   #12 (permalink)
Member: 201963
Hello,Ifinity Team,
module v2.76
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
Old 04-06-2009, 08:05   #13 (permalink)
Star75's Avatar
Member: 53198
Sonork: 100.1589499
Thanks Meter: 819
module v2.79
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize ...
Finalization Done
COM5 [VCP0] selected
module  v2.79
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
chip: 0031:7594:5A76
high speed boot Off
Boot Done
Initialize ...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
921600
Set baud Done
ver. sw 1: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_0TMC1_26B.BIN
warning: optional information is not found,
if phone works well just ignore this warning
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading: flash[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_0TMC1_26B.BIN]...
file saved: E:\Infinity Box\ChineseMiracle\flash[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_0TMC1_26B.BIN]_20090106-221317.B0M.bin
Finished, time used: 681 sec
Same phone and SW version but HW and inside SW different
Wait i will upload other file
Old 04-07-2009, 10:39   #14 (permalink)
Star75's Avatar
Member: 53198
Sonork: 100.1589499
Thanks Meter: 819
The 2nd test and post result
flash[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN]_20090407-141912.B0M.rar
Pass; vnmobile
The Following 3 Users Say Thank You to Star75 For This Useful Post:
Old 04-07-2009, 17:08   #15 (permalink)
Member: 201963
Thanks,
result- no power on the phone
Page generated in 0.36627 seconds with 9 queries
