04-08-2009, 11:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 432765 Status: Offline Thanks Meter: 65 | sony ericsson t250i unlock success module v1.32 Device: Sony-Ericsson-T250i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89880900010001:89880900000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Sony-Ericsson-T250i_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20090408-111833.80E.bin Read data done Check data ... Check data done Write ... .......... flash: 89880900010001:89880900000000 Write: simlock Write done Finished, time used: 116 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to fessi For This Useful Post: |
04-08-2009, 17:50 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
08-07-2009, 13:08 | #3 (permalink) |
No Life Poster Join Date: Aug 2004 Location: india Age: 51
Member: 78028 Status: Offline Thanks Meter: 90 | COM11 [VCP2] selected module v1.32 Device: Sony-Ericsson-T250i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89880900010001:89880900000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Sony-Ericsson-T250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20090807-173053.80E.bin Read data done Check data ... Check data done Write ... .......... flash: 89880900010001:89880900000000 Write: simlock Write done Finished, time used: 118 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to devika For This Useful Post: |
Sony ericsson w580i unlock successfully with rj45 cable | shmily | SETool2 | 0 | 11-17-2009 14:02 |
Sony Ericsson T303 Unlock Successfully by INFINITY | irish_4 | Infinity-Box | 12 | 10-14-2009 14:47 |
sony ericsson j100 unlock successful | guljee786 | Infinity-Box | 1 | 03-30-2009 07:21 |
sony ericsson T250i unlock? | fishlove | Sony Ericsson | 8 | 12-10-2007 22:58 |
sony ericsson k610 unlock successfully | Likom | Cruiser Suite | 15 | 06-05-2007 12:34 |
